Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Module for both blinkers module on left side
Old Jun 28, 2019 | 02:10 AM
Bradw71019's Avatar
Bradw71019
3rd Gear
Default Module for both blinkers module on left side
I’m a handicap veteran and only have the use of my left arm I’m looking for a way for my blinkers where only use one control module on the left-hand side to control both blinkers. Does such a module exist and if so where can I find it. The blank your module is all I have left the find so I can start running again.
Old Jun 28, 2019 | 02:20 PM
inverse121's Avatar
inverse121
You can use this part from Harley.
You will need to pull the button and wiring from the right side and move it to the left side and put it in one of the slots.
https://www.harley-davidson.com/stor...09-7024802b--1
David Witt
Feb 5, 2019 09:54 PM
Fblo1690
EVO
Jun 22, 2018 12:46 PM
99embrey
May 31, 2018 06:27 PM
Rob Wynn
May 8, 2018 05:53 AM
Angeltrumpettech
Feb 11, 2018 03:15 PM
