Question for Predator Front Mount Users
Old Feb 14, 2018 | 11:01 AM
blueangel73's Avatar
blueangel73
I installed mine mostly as a replacement do to mileage wear. I had 50k on my ride and was ready for the replacement, so I decided to go spend a little more money and get something that added more protection to the isolation component from oil and something that looks better. As for handling and vibrations, it is really hard to say because I change a few other things around the same time and my ride is no where near the same bike it was when I purchased it in its stock form.
Old Mar 1, 2019 | 10:16 PM
NVNobody's Avatar
NVNobody
I just ordered a predator for mine today in hopes of tightening up the bike in corners. My factory front mount is toast with 18k on it. Don't like that Dyna wobble at all haha. I'll report back when I get it installed and riden.
Old Mar 1, 2019 | 10:53 PM
wyotana's Avatar
wyotana
I've had mine on for about 7,000 miles. It made virtually no difference in vibration (mine wasn't bad IMO to begin with) but I could tell after the first hard corner I took that it was worth the money. Bike felt like it was on rails.
Old Mar 2, 2019 | 08:05 AM
Dynaglide92's Avatar
Dynaglide92
Originally Posted by Tnbrit
Did installing the Predator make a noticeable reduction in motor vibration on your Dyna?Would you say it was worth installing just for vibration reduction.?
Thanks.
never installed for vibration reduction more for handling performance any vibrations dampened is a plus but nothing to brag about.
Old Mar 2, 2019 | 08:23 AM
archergodwin's Avatar
archergodwin
Yeah, don't know that it reduced the vibration much.. but, the handling got better and I don't have to worry about the engine dropping forward and putting stress on the exhaust again... busting heat shield welds... that can be a little expensive from V&H.
I will say this on top of why people buy the Predator... if you've never done the vehicle alignment on your dyna.. DO IT. I would almost swear that the alignment was never done by either the factory or the dealer when it was finished assembled.
I had the high speed corner butt clencher wobble a couple of times, and after the vehicle alignment + front mount shim, it handled like a different bike.
Old Mar 2, 2019 | 10:57 AM
Max Headflow's Avatar
Max Headflow
I agree. If you want to add a a stabilizer, go for a link that uses the stock motor mounts. That way when they ware out, you can get replacement parts easy. Alignment is the first thing to look at.
Old Mar 2, 2019 | 11:10 AM
AwesomeAustin's Avatar
AwesomeAustin
Originally Posted by TinCupChalice
Quoted for truth
The Dyna's mounts have a critical role. Braking and acceleration forces from the rear transmit to the frame through the mounts, and engine torque is pitching the engine up and down at the front mount; the mounts need to be stiff enough to keep the wheels from going out of alignment in both vertical and longitudinal axis and the Dyna relies on the top stabilizer to keep the engine in vertical alignment.
While it may have worked in the pre-TwinCam era, now the mounts are overloaded; the bikes are heavier and engine displacement has gotten larger. To me the idea behind the Predator was to add stiffness and damping to the longitudinal, vertical, and yaw axis, along with the addition of a stablizer link to prevent any side to side motion.
Basically, the OEM mounts are a flawed design and HD gave the mounts no thought at all; it took the aftermarket to come up with some properly engineered solutions. The Predator is a very elegant solution; it may add vibrations at lower RPM's but the trade off in handling and stability is absolutely more than worth it. I doubt their goal was to reduce vibrations when they designed the Predator mount, but rather to correct the inherent flaws of the HD mount and improve the handling and stability of the Dyna.
Try the Predator, you will become a believer
Would you recommend the predator for evo powered dynas?
Old Mar 2, 2019 | 11:43 AM
Scarydog's Avatar
Scarydog
My predator motor mount did at least 2 things.
1 it reduced th vibrations in my hands. I used to shake my hands every 5 min on the highway which seemed odd for a dyna. My rigid sporty chopper wasnt that bad.
2 it stopped the front end crashing on breaking and just overall mushy front end suspension feeling.
Once I installed it I could tell the bike felt higher. After looking at the mount I could see it was collapsed which screwed the whole purpose of it up.
Shortly after I also replaced yhe rear mount and added the Sputhe positrack stabilizer. The bike feels a lot better now.
I did buy my '05 FXD used with 32k on it.
Old Mar 2, 2019 | 06:32 PM
hell hound's Avatar
hell hound
at some rpms it was super smooth and some rpms it vibrated more. on really big bumps my pipe would hit the frame. too much verticle movement for me. I took it off. I have stock mounts with sputhe stabilizers and very happy
Old Mar 2, 2019 | 06:57 PM
Max Headflow
Same here. The motor in the bike is a high compression 116 (4 5/8 stroke) tho.
