new headlight with halo install question
Old Feb 16, 2018 | 08:28 AM
mclowrider's Avatar
mclowrider
Stage II
Default new headlight with halo install question
Hi all, I am fairly new to this site, and had a question to ask, I have a 2014 low rider, and recently purchased a duraflux daymaker, these are the directions the provided, "there are three pins plug, just plug to your bike headlight, and there is another wire to connect to your bike DRL", this Is all I have for instructions, and cant seem to find anything on the net on how to install, I understand to plug the three pin plug, but how do I wire the extra wire into the DRL? sorry if this sounds confusing, I appreciate any input!
Old Feb 16, 2018 | 09:20 AM
TriGeezer's Avatar
TriGeezer
There should be another unused connector that is used in the European market. It should have power constant with the ignition on. connect the halo to that if you want the halo on constant with the ignition on.
Old Feb 16, 2018 | 10:28 AM
mclowrider's Avatar
mclowrider
Stage II
thank you for the response, I am based in the US, should this still be the case? will thre still be an unused connector on my bike? and is it located in the headlight housing? I appreciate the help!
Old Feb 16, 2018 | 10:33 AM
robertomendo's Avatar
robertomendo
Yes, and yes.
havenolife
Electrical/Lighting/Alarm
Jun 28, 2014 11:01 AM
DeathProof72
Jun 14, 2012 08:47 AM
JoeGrapes
Nov 28, 2008 11:00 AM
klf33
May 30, 2008 10:46 AM
skullhead
May 19, 2008 10:57 AM
