Wheel fitment question
Old Feb 19, 2018 | 08:53 AM
SC07Bobber's Avatar
SC07Bobber
Default Wheel fitment question
I’m a novice to wheels so please bear with me. I have a general fitment question. I have a 2007 FXDB with stock 17/19 wheels.
I want to upgrade to an 18x5.5” and 21x2.15” set of RC wheels. I already know that they’re set up with 1” bearings so my 1” axle is fine. No problem there.
Can I use the stock rotors and will they bolt right up without modification? Or, do I need the matching rotors? I’d rather use the stock rotors.
Can an I use my existing stock pully or does a new one need to be installed? I’m not sure how pullies relate to wheel size. So this might sound like a dumb question to you. I have no clue.
Anything else I should be aware of?
Thanks in advance for any advice.
Old Feb 19, 2018 | 11:45 AM
Ghost_13's Avatar
Ghost_13
A bunch - and with what I tell ya - still won't be able to answer your main questions definitively
Front wheel..., 19 to a 21 - will it clear the fender (rear likely will)
You'll need spacers to properly align both wheels as I'm sure the hub width will be different from what's on there now
These can be bought in bulk w/ various sizes pretty cheap - depending on material (SS or aluminum) and color
Will the rotors fit - will need to mock up to determine
Bolt pattern and wheel clearance will be the determining factor
If you do / can reuse the rotors - will need new hardware - as those bolts are a one and done type application
Depending on hub width - calipers may need spacers to align / center w/ rotors
Pulley - is dependent on tooth count..., not necessarily wheel diameter
Putting on a bigger rear tire will throw off the speedo - but not enough to get in a twist over
Will the pulley fit - will need to mock it up to tell - and again - use new hwdr, these are also one and done
Use red loctite on the rotor / pulley bolts..., and torque to spec (don't half *** this part)
Add'l questions - ask - answer the best we're able (and yeah..., I did swap the spokes out w/ mags on the WG)
Ghost
Old Feb 19, 2018 | 02:40 PM
cvaria's Avatar
cvaria
double check 2007 front and rear axle sizes axles sizes
Old Feb 19, 2018 | 04:52 PM
SC07Bobber's Avatar
SC07Bobber
Ghost
Thanks for the info Ghost!
Old Feb 21, 2018 | 07:21 PM
Tall Timber's Avatar
Tall Timber
Also 21X3.5 would give you a bit more rubber on the road (look cooler) than 21X2.15.
SC07Bobber
Wheels/Tires
Feb 23, 2018 10:16 PM
MCSarge
Mar 7, 2017 03:20 PM
justin_ryan
Jun 24, 2015 05:44 PM
CSS899
May 19, 2015 12:24 PM
oly737
Feb 28, 2010 10:50 PM
