Headlight bracket
Old Mar 13, 2018 | 11:13 AM
Mark E Lemon's Avatar
Mark E Lemon
6th Gear
Default Headlight bracket
Hello. I have purchased a Memphis Shade fairing for my 99 FXD. When I went to install it, I noticed the aluminum shroud over the light needed to be removed so the fairing fits. The light assembly is attached to this shroud and there is nothing on the fairing it attachs to. Is there a bracket to reattach the light so it fits in the circular hole in the fairing? Thanks.
Old Mar 13, 2018 | 11:47 AM
emperor wurm's Avatar
emperor wurm
You're referring to the headlight brow correct? That needs to be removed and you need to get a bottom mount headlight. There should be a hole in the middle of your bottom tree. A morning block can be installed there and the new headlight attaches to the morning block.
emperor wurm
Mounting block, not morning block....
Old Mar 13, 2018 | 11:58 AM
emperor wurm
You can buy the bottom mount led headlight bucket from moco for around 50 dollars. This does not include the headlight itself, but you can install your stock non-led headlight in this bucket and run that. I did this until I bought an led headlight.
Old Mar 13, 2018 | 01:00 PM
JoshFXDL's Avatar
JoshFXDL
When I changed my handlebars/riser I picked up a like new take off street bob headlight and mounting block off Ebay for $50-100 (don't remember).
Old Mar 13, 2018 | 01:12 PM
Mark E Lemon
6th Gear
Nice . Thanks.
Old Mar 13, 2018 | 08:11 PM
Johnnyh14's Avatar
Johnnyh14
Lower tree on my 2003 Fxd had to be drilled for the bolt hole. Nothing from the factory there. Used a cordless right angle drill to make it straight.
Old Mar 14, 2018 | 12:19 PM
JoshFXDL's Avatar
JoshFXDL
thats interesting, my 16 FXDL was drilled, just screwed right in.
HD_Matt
Dec 19, 2016 03:57 PM
nickhtanaka
Sep 8, 2016 04:39 AM
04FXDI
Jun 21, 2015 10:59 AM
flhtvtwin
Apr 1, 2014 05:48 PM
lhcstreetbob
Jun 27, 2009 09:05 PM
