Thunderheader problems
Old Apr 4, 2018 | 08:04 PM
dyna_rider84's Avatar
dyna_rider84
Default Thunderheader problems
Hey guys, so I just installed a thunderheader on my 2000 fxdx. Sounds awesome and I love it. But the problem is I have forward controls and the brake lever rod is rubbing the inside of the pipe. Anyone had this issue before? If so how did you deal with it? Appreciate any help guys thanks!
Old Apr 4, 2018 | 08:51 PM
xknucksx's Avatar
xknucksx
Is your pipe for forwards? Thunderheader has a forward specific and a mids specific pipe.
Old Apr 4, 2018 | 08:54 PM
dyna_rider84
Yes pipe is for forwards. It fits, but like I said it just rubs a lot.
Old Apr 4, 2018 | 09:11 PM
rideon's Avatar
rideon
Try bending the rod a touch.
Old Apr 4, 2018 | 10:55 PM
supermanotorious's Avatar
supermanotorious
look at my thread for the Bassani install challenges, you'll see my easy to do brake rod offset
https://www.hdforums.com/forum/dyna-...hallenges.html
Old Apr 4, 2018 | 11:22 PM
riderboy1961's Avatar
riderboy1961
Loosen your Thunder Header "Head Mount Nuts" - Loosen or take off any other Header to frame mount bolts if there are any (Ive never had a Thunderheader)
Then... with the Header Nuts Loosened... Twist/Rotate Outwards the Header just a little and re-tighten the Header "Head Mount Nuts".
Old Apr 6, 2018 | 09:46 PM
VT81's Avatar
VT81
The 3 Thunder headers i'm running on my 01 FXDX,89 FXR and 2003 FXDL Anniversary lowrider fit like gloves. You "May" have to apply a torch with mild heat on the master cylinder Brake pushrod to achieve a slight bend to eliminate that pipe rubbing and a clear smooth rear brake rod pressure/feel .
cody.a.e
Mar 8, 2018 12:34 AM
Chritoff
Mar 6, 2013 12:57 AM
relli
Jul 21, 2007 07:00 AM
rac43
Mar 13, 2007 01:58 AM
Psycho
Feb 21, 2007 05:36 PM
