FXDLS Puking Oil from Ventilater
Old Apr 9, 2018 | 06:14 PM
liberty.mike's Avatar
liberty.mike
Default FXDLS Puking Oil from Ventilater
Just picked this (new to me) bike up from dealer, trailered it 130 miles home after a brief ride. Has 500 miles on it and after getting home I took it for a 20 minute ride, oil was dripping from AC. Pulled the cover and it looks like it's got moisture/condensation foaming out of the breather vents. Checked the oil level and it is about half way on the fill/full indicator.
Suggestions?
Old Apr 9, 2018 | 06:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Clean as best as you can, drain the oil and run some fresh oil in it for a couple of hundred miles repeat. Read the owners manual real close for correct amount, don't forget the oil filter. That looks like some serious condensation from short test rides or parking lot start ups at the dealership. That oil needs to be replaced/flushed. When have your oil in go for a long ride, about an hour till the bike is good and hot. I'd send that pic to the dealer you bought it from. Good luck.
Old Apr 9, 2018 | 06:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No panic...
If the oil in the tank is milky, then you should change it.
If the oil in the tank looks normal, just wipe the mess up and ride.
Short rides not getting engine and oil up to operating temp is the cause of this, usually seen during cold weather.
Old Apr 9, 2018 | 07:35 PM
liberty.mike
Thanks guys. I am going to change oil and filter even though they claimed to have done a full service. I guess the condensation would be at the top and explains why it foamed out the vents, but it was oil that dripped or puked all over the engine, pipes and made a nice mess. I assume it hasn't been ridden since the Original Owner bought it last year and traded it in with under 500 miles on it. Love the ride, and it has lots of power! I sent pics and suggested they send me the oil and filter, crickets.
Old Apr 9, 2018 | 07:39 PM
Campy Roadie's Avatar
Campy Roadie
Route those breathers to ground and plug the backing plate holes.
Old Apr 9, 2018 | 07:47 PM
liberty.mike
Is there a thread I might find more info on how to do what you suggest? Newbie to the Dyna/TC. My M8 dripped a little but I attributed that to overfilling buy dealer. Different dealer than this go around.
Old Apr 9, 2018 | 08:03 PM
Johnnyh14's Avatar
Johnnyh14
They make a chrome tube with banjo fittings to pick up the oil and run it to the ground. Mine doesn't leak unless I put a little too much oil in at a change then stops when is is right.
Old Apr 9, 2018 | 08:21 PM
2500hdon37s's Avatar
2500hdon37s
DK customs has a few different breather options.
while the performance aspect of venting your crank case breathers to the atmosphere versus back into your intake is negligible, your engine will thank you. Best to do it while your engine is young! Keeping all the carbon and oily goo from forming on your pistons and intake tract by getting the crank case vents out of the intake is only good.
Old Apr 10, 2018 | 09:32 PM
crusader1xxx's Avatar
crusader1xxx
Go to DK customs website and read about breathers...they have some excellent advice and some good setups for doing it.
I went with the stealth breathers and put my catch can under my seat....
Old Apr 10, 2018 | 09:56 PM
Ghost_13's Avatar
Ghost_13
Suggestions?
Likes been said , vent to atmosphere - then - allow the motor to seek its own oil level (this will be when oil stops puking out the vent tube)
Mark that level on the dip stick - both the hot level.., and cold
Bingo - that's that motor's fill point (every motor's is just a bit different) - and never exceed it
Then - always check - either when cold..., or..., when hot - never compare one to the other
Cold is better imo because that's the temp when oil changes occur
Vent kits are a dime a dozen..., takes about a beer to install
Ghost
