Progressive shocks WTF????? Update!!!!
Old Jun 27, 2007 | 09:58 AM
05 Wd Gld's Avatar
05 Wd Gld
Default RE: Progressive shocks WTF?????
Well last night I changed out the defective shocks for a set of 440's that I purchased from Dennis Kirk. When I took off the shock on the right side, I had some oil leaking out, no big surprise. When I took the left shock off the remaining oil poured out on to the floor and yes on my boots. Nothing like adding insult to injury.
When I removed the shock from the bike it actually came apart in two pieces. The top of the shock cartridge was completely separated from the rest of the cartridge. It looks as is someone took a can opener and opened the top of it. From what I can tell the tech at Progressive is most likely correct. Dyna is too heavy to have the 11 inch shocks. If you are going to have them set on the softest ride that will only make matters worse. Apparently they must have been bottoming out, causing the damage to the shock cartridge.
Just a word to the wise, if you have those 11 inch shocks on your Dyna, you may want to stiffen up those shocks before you have the same problem. If you don't and are considering it, then I would go with a taller shock and keep the ride a little stiffer. Just thought you would want to know this information before some of you had the same problems.
Brion B
Mar 31, 2013 12:49 PM
SC_Compact
Mar 20, 2008 08:23 PM
Lildude11d
Sep 24, 2007 11:19 PM
woodreaux
Sep 12, 2007 10:27 AM
woodreaux
Sep 12, 2007 10:09 AM
