Riser Installation on 04 FXDLI
Old May 18, 2018 | 12:21 PM
glozano805's Avatar
glozano805
Stage I
Default Riser Installation on 04 FXDLI
I have a 04 FXDLI and I purchased 9'' risers, wanted to know if I need cable extensions or if I have enough stock wire slack. I have read different threads online starting both claims. Can someone verify which direction I need to go in, please let me know
Old May 18, 2018 | 01:54 PM
JohnMn's Avatar
JohnMn
9"s is a lot to ask of stock,, my thought is your going to need all new cables and brake line with wire extensions.
The only thing to do is go for it,, take a day and try the install if it doesn't work you can at least make mock measurements of what you need by using a section of wire or string/yarn. then put everything back so you can ride until you get the needed parts.
Old May 19, 2018 | 11:07 AM
Mchad's Avatar
Mchad
I managed 8” tbars on my LRS, without changing anything, and there was enough wire and clutch cable for more, but the brake line was my limiting factor. The clutch I did have to rerouted to come up the right frame rail and cross over the steering head, but that only cost me two clamps.
Old May 19, 2018 | 02:45 PM
cggorman's Avatar
cggorman
I couldn't get an extra 9" out of my stock 99 DWG wiring and cables. Depends on the bars. If you stick with the mini apes and add 9" to that...doubtful.
Kingwilliamxxvi
Jul 8, 2019 02:58 PM
TerryMcQ
General Topics/Tech Tips
Dec 19, 2018 11:06 AM
Loud1
Oct 4, 2007 02:43 PM
Sean
Dec 1, 2006 02:56 PM
WARG
Jun 14, 2006 02:33 AM
