Injectors
Old Jun 24, 2007 | 10:58 AM
Nach's Avatar
Nach
Default Injectors
Reading another recent post got me to thinking about the fuel injectors again. Previously I remember reading several people with the 06 changing theres out. Just cruious as to how many have done this and why, also what did you replace them with and what was ness. to do that?
Old Jun 24, 2007 | 11:14 AM
Cynic's Avatar
Cynic
Default RE: Injectors
I haven't changed mine, and I'm very happy with howmy 06(built Dec 05) runs/performs. I just have a small starting issue, where if I don't keep the button pushed in for a fraction of a sec after it first fires it will kick back and die. I think it's more ignition-timing related, or maybe even a not so good battery so I'm not concerned about changing the injectors at all. I can't even remember what the change was supposed to fix?
Old Jun 24, 2007 | 11:37 AM
Oilslick's Avatar
Oilslick
I've still got my 8° injectors. Runs fine.
Some bikes had cold start / driveability problems (surging). 25° injectors were supposed to cure it.
Thereare a ton of threads covering this in the forum.
Old Jun 24, 2007 | 10:42 PM
soup48's Avatar
soup48
Mine where changed. The problem was the engine would rev-up at a stop light and the check-engine light would go on at the same time. After the engine slowed down to normal idle the light would go off. Then the bike would have to be reved-up to take of from a stop.
Old Jun 25, 2007 | 08:36 AM
tbone52's Avatar
tbone52
Changed. Bike would stall leaving stops. Almost in the middle of intersection. Very dangerous. Cold start problems occasionally. Surging in low gears. All is well now. No remap. Bike is still stock mufflers and air cleaner.
way2exhaustd
May 16, 2010 09:33 AM
06DEUCE
Jun 11, 2006 08:45 AM
superdog48
Apr 30, 2006 03:25 PM
oldfartjc
Mar 2, 2006 09:35 PM
UltraScoot
Jan 8, 2006 10:07 PM
