P0261 code
Old May 27, 2018 | 11:00 AM
Tileman2692's Avatar
Tileman2692
Default P0261 code
I spoke too soon the stumbling problem I've been experiencing has come back. P0261 front injector open/low comes up, some injector cleaner did the trick for a while but the prob. Is back. Do I need new injector?
Old May 27, 2018 | 11:05 AM
rigidthumper's Avatar
rigidthumper
More likely a wiring or connector problem. You can swap injectors front to rear, rear to front, clear codes and ride. If the code switches to rear injector open/low, then replace that injector. If the front code comes back, then you have a wiring or connector issue.
Old May 27, 2018 | 09:19 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by ws6 formula
might be a bad wire. Several owners had the same problem and it was caused by no service loop in the wire to the injector. So when the engine is rocking in the rubber mounts it is pulling on the wire, the insulation on the wire stretches but the wire doesn't and breaks.
Old May 27, 2018 | 09:37 PM
Nickd2689's Avatar
Nickd2689
thats what id do. Best, easiest way and it won’t take more than 10-15 min
Old May 28, 2018 | 07:08 AM
Tileman2692
Great ! Thanks
CheneyColin
Electrical/Lighting/Alarm
Sep 12, 2018 02:11 PM
AbeVigoda
Sep 3, 2018 02:54 PM
mdanehart
Jul 26, 2018 05:55 AM
micmoren
Milwaukee Eight (M8)
Feb 9, 2018 07:26 PM
man4mopar
Apr 18, 2009 12:07 AM
