Lifting FXDL
Old Jun 24, 2007 | 06:04 PM
Grayzone's Avatar
Grayzone
Default Lifting FXDL
has anyone come out with a beter way of lifting an FXDL for servicing?I have a regular 1500Lb bike jack
Harley has these adapters http://www.harley-davidson.com/gma/g...bmLocale=en_CA any one used them?
Old Jun 24, 2007 | 06:34 PM
mud's Avatar
mud
Default RE: Lifting FXDL
ORIGINAL: Grayzone
any one used them?
They work great
mud
Old Jun 24, 2007 | 06:43 PM
piniongear's Avatar
piniongear
This is all I ever use. Cost?......just the time it takes to cut some pipe and weld it up.........pg
[IMG]local://upfiles/8331/9B70EB9873BE4BAAAE46D1AE3D285A04.jpg[/IMG]
Old Jun 24, 2007 | 08:11 PM
Grayzone's Avatar
Grayzone
thanks great PICS
I'll order the adapters want to have them for the first service .....should be next weekend
Old Jun 24, 2007 | 08:23 PM
DGlide04's Avatar
DGlide04
You make almost anything for a lot less that'll work on getting the back wheel off the ground, but if you want the lift to work on both wheels at the same time, you'll need these adapters. This is actually one thing from the MoCo that works and is reasonably priced, but don't let on or they'll up the price.
Old Jun 25, 2007 | 01:52 AM
docsg's Avatar
docsg
I recently purchased the J&S Jack for my FXDLI. It slides under the frame easily and has rubber covers on the lift plates. It operates VERY smoothly and it is one of the best accessories I have bought for my bike. I use it every time I clean my bike or just to do some minor repairs or fluid changes. The owners of J&S suggested that I don't waste my money on the adapters and so far they are right. No marks or scratches on the frame after multiple uses and the bike is very stable when the jack is elevated.
Old Jun 25, 2007 | 03:06 AM
TOMMAY's Avatar
TOMMAY
I don't know about the J&S jack,but with my Sears jack if you don't use the Frame adaptors you're lifting with the oil pan not the frame on the left side.
Good Luck
Tom
Old Jun 25, 2007 | 09:38 AM
Protrucker's Avatar
Protrucker
I use those adapters for both, my wife's Low Rider & my Street Bob. I have the lift that came from Sam's Club (same as Sears, but lower price) & I have to roll thebikes up on some 2 X 8's (scrap lumber I had laying around) to be able to get the lift under with the adapters on the frame. The Street bob only needs a piece under the rear tire, but the Low Rider needs pieces under front & rear. I also put a piece under the jiffy stand so the bike doesn't lean over too far.
Old Jun 25, 2007 | 09:44 AM
wisemx's Avatar
wisemx
To make this easier I put hooks on the garage ceiling.
I hang rubber coated bike straps down to the bike.
Hook them up while sitting on the bike.
Then much easier to get the lift in place.
Instead of ordering the special adapter I made my own, glued low-nap carpet in key spots.
Wasn't that difficult and now I can get the bike up in under a minute with no worries.
Gil Aguilar
Mar 20, 2018 12:45 PM
ROCKOUT Rocker Products
Apr 6, 2016 02:01 AM
casique
Nov 30, 2007 07:47 PM
mopardave
Oct 24, 2007 07:35 PM
anubisss
Nov 18, 2006 10:22 AM
