Clutch adjustment screw
Old Jun 16, 2018 | 05:46 PM
Dominic Catanese's Avatar
Dominic Catanese
2nd Gear
Default Clutch adjustment screw
I’ve been looking around and cannot find where I can get a new clutch adjustment screw and plate. Maybe just the dealership which will over charge me as usual.
Old Jun 16, 2018 | 05:57 PM
QC's Avatar
QC
You could always try fleabay.
Old Jun 17, 2018 | 09:24 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome to the site.
Old Jun 17, 2018 | 10:06 AM
WS6 Formula's Avatar
WS6 Formula
Find the part numbers here: http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Google search: https://www.google.com/search?q=3790...w=1280&bih=667
eBay: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
Old Jun 17, 2018 | 10:59 AM
Dominic Catanese
2nd Gear
I was adjusting my clutch and put a "little" too much torque on the screw. I believe the plate is now stripped as the screw no longer stays in. Other than the dealership, where else can you buy this part and what exactly would I be asking for? Tried looking up clutch adjustment screw plate and came up with nothing. Thanks
Old Jun 17, 2018 | 11:10 AM
carguy1959's Avatar
carguy1959
Are you talking about the clutch adjuster screw behind the derby cover? Or the adjuster on the cable? Also what year and model bike? I have 17 FXDL 6 speed. Mine shows in the repair manual that the trans main shaft is the part that supports the clutch assembly. If that is what is stripped, your going to have to take apart the trans. Good luck...
Old Jun 17, 2018 | 11:14 AM
Dominic Catanese
2nd Gear
the adjuster screw behind the derby cover. Is it just the release plate that I need to fix the problem? The screw itself seems fine
Old Jun 17, 2018 | 11:29 AM
carguy1959's Avatar
carguy1959
I added to my post #2.
Old Jun 17, 2018 | 12:12 PM
Dominic Catanese
2nd Gear
I found what I needed. Its an 06 Super Glide. Just the threaded release plate and I'm buying a new adjustment screw and nut for good measure also. Should be a fairly quick and easy fix.
Old Jun 17, 2018 | 10:57 PM
archergodwin's Avatar
archergodwin
22 inch/lbs... not 22ft/lbs... ..
btw 37903-90 RELEASE PLATE
No Tyme
18
Oct 24, 2018 03:13 PM
SC07Bobber
Oct 1, 2018 04:40 PM
ReverendBell
EVO
16
May 15, 2016 09:50 PM
BKSinAZ
Dec 19, 2012 09:04 PM
strippedthread1
May 23, 2008 06:59 PM
