Noise coming from cam chest area.
Old Jun 19, 2018 | 01:36 AM
AFDynaRider's Avatar
AFDynaRider
Default Noise coming from cam chest area.
My bike has always had a noisy top end (like a sewing machine on steroids) but I have long ago accepted it as normal and learned to live with it.
But now I have started hearing a different noise from the cam chest area (I think). It's hard to describe. To me it sounds like a squeaky bicycle chain/grinding metal on metal noise.
I have been hearing the on and off high pitched squeaking for a week but thought it was just wind noise from my helmet or something until tonight when I got home from work I decided to leave the bike running and investigate a little bit. The noise is the most noticeable if i stick my head under the bike near the cam chest.
The bike is a 2012 Wide Glide with 23,000 miles on it. Everything is stock except pipes, air cleaner, and fuel pack.
is it likely to be cam chain tensioners shoes failing? I wouldn't think so but I'm no expert. Am I being paranoid? I plan on opening up the cam chest to take a look but what else should I look at?
Thanks for any help. I know that noises are hard to diagnose over the internet but I want to see what you guys think before I do something drastic.
Old Jun 19, 2018 | 03:18 AM
Flstcjay's Avatar
Flstcjay
if you are hearing noise at the cam chest you’d best have a look. Even if only for piece of mind. Squeaky metal on metal sounds are not normal.
Old Jun 19, 2018 | 05:59 AM
joe40x's Avatar
joe40x
Start with the obvious and check for a loose or leaking exhaust.
Old Jun 19, 2018 | 08:28 AM
archergodwin's Avatar
archergodwin
Had some similar noises on my '08 FXDC w/72k miles. Bothered me enough I stopped riding it till I could figure out what's up. I opened up the primary and cam chest, and really didn't see anything wrong, or out of the ordinary particulate in the drained oil. I went ahead and replaced my Hayden primary chain tensioner with a Baker, and installed new Andrews cams, bearings and Fueling lifters, and a kit to lock the rocker shafts in place, all last weekend. (good time to replace some weeping rocker box gaskets anyway).
Wish I could tell you what the outcome is... I flubbed the o-ring in the fuel QD hooking the fuel line back up.. grrrr.
However, I intend to pull that sucker out tonight, replace it and fire that ****** up! I'll let you know in a day or so if that did anything to the noises I had.
Old Jun 19, 2018 | 09:00 AM
AFDynaRider
Thanks guys. I don't know when I will be able to tear into it but I will post updates when I do.
Old Jun 19, 2018 | 09:16 AM
brownie4412's Avatar
brownie4412
Can you hear it while riding or is it more pronounced at idle, or when shutting it off? Maybe check your compensator nut. I know you said it sounds like its coming from the cam chest, but noise travels.
Old Jun 19, 2018 | 09:30 AM
Jackie Paper's Avatar
Jackie Paper
Your 2012 has a modern roller chain on delrin tensioner shoes that once grooves in stops wearing. So they are good probably 100k. Maybe long term like +10 years may hot oil harden them and they may crack.
I doubt that is your problem. Put a stethoscope on it at idle. If it is smooth hum. Don't worrying about it. You are probably hearing the exact opening of the valves thru the open exhaust.
Old Jun 19, 2018 | 10:22 AM
Krazy8s's Avatar
Krazy8s
Absolutely look into it NOW!!
Or you may end up going thru the same nightmare that I did....
Old Jun 19, 2018 | 10:30 AM
mmesa005's Avatar
mmesa005
I agree with Krazy8s - check it now, don't wait!
Old Jun 19, 2018 | 11:01 AM
Max Headflow's Avatar
Max Headflow
Agree with others. Could be a stuck Tappet roller or any of the things mentioned above.
