Removing Fork Brace Cured Wobble
Old Jun 24, 2018 | 04:01 PM
fxdx1985's Avatar
fxdx1985
Default Removing Fork Brace Cured Wobble
I know no one cares, but just kind of throwing it out there so when someone does a search this might be an option for figuring out a wobble. I’ve been trying for a loooooong time. I’ve gone through motor mounts, suspension, tires, air pressure, adjusting a million settings on the FXDX forks etc etc...
I was getting prepped to rip the forks apart, I took the fork brace off the fork and the bike automatically popped up a good inch and a half to 2 inches in the front.
Essentially, it seems the fork brace was putting outward pressure from the center of the forks to the outside, thus causing the springs or one spring to bind inside the forks (or possibly compress all the way down and never come up). I went for a rip today with no brace and it’s like a whole new bike. No brake dive, no wobble, no issues in twisties. Maybe it was user error or the fact that it was an $80 Custom Chrome fork brace from eBay, but either way, it’s done.
I’ve seriously been chasing this for 3 years and I’m elated that it was a free fix!
Old Jun 24, 2018 | 04:50 PM
F86's Avatar
F86
My fork brace experience (not that anyone cares about this either! )
I have a Superbrace. The first time I installed it, things were pretty much fine. Then for some reason that I can't recall, I had to remove it (maybe swapping the front fender). I changed other things at the same time, which confused my upcoming issue... Handling wasn't TERRIBLE, but just didn't seem right. I had recently installed a Predator front mount, done some alignment work, adjusted rear belt tension, etc. Since the brace had never caused an issue before, I didn't really think about it and chased all these other things, to no avail. Finally I removed the brace and went for a ride. The issue was gone, although so was the benefit of the brace. I reinstalled the brace, with a lot more care. I didn't do it on the side stand, I lifted the bike enough to straighten the fork but keep a little bit of weight on the front wheel. I installed the brace hand tight, lowered it a little and bounced the fork around a bit. With the bike fully upright, I tightened the brace bolts progressively and then torqued them. Went for a ride, and problem solved! Handling was back to normal, and so was the benefit of the brace.
Despite what the instructions say (mine said you could just install the brace on the sidestand), I think it's really easy for a fork brace to cause a little bit of stiction, or misalignment, or binding, etc. Not enough to be a disaster, but enough to create a negative effect. Now that you know your issue was brace-related, you might try reinstalling it carefully...
Old Jun 24, 2018 | 05:33 PM
fxdx1985's Avatar
fxdx1985
Exactly what my deal was. I installed it 3 years ago, on the side stand and had no issues at first. Apparently it slowly caused an issue, so slowly that I never even thought about it. I might switch to a super brace or just toy with this one.
Old Jun 24, 2018 | 09:49 PM
Mchad's Avatar
Mchad
Interesting. When I installed my superbrace the instructions specifically said center the bike, loosen the axle pinch bolts, tighten the brace, then tight axle pinch bolts back up.
Old Jun 24, 2018 | 10:11 PM
F86's Avatar
F86
I stand corrected, as I just checked online. You're totally right, it does say to stand the bike up. I remember doing that when I first installed it, but I somehow thought that wasn't what it said. My mistake. I guess my point is that I've installed it three times, and the second time something was wrong that caused slightly sub par handling. They do take a little bit of fiddling sometimes to get perfect...
Old Jun 25, 2018 | 06:43 AM
Antonio Balls's Avatar
Antonio Balls
My brother in law has been racing and building motorcycles his whole life and when I showed him the Superbrace a few years ago he commented on how critical it is to install it with exacting precision. He said it is common for the fork tubes to bind up while compressing at exactly the wrong time if not aligned properly. Not something to be taken lightly.
Old Jun 28, 2018 | 07:24 PM
adamsrotors's Avatar
adamsrotors
just wanted to bump this for some love.
going to try taking it off rn and run it. then reinstall on a lift, straight up n down. thank for the insight!
Old Jun 28, 2018 | 08:31 PM
fxdx1985's Avatar
fxdx1985
Right on, that’s why I shared. Hopefully someone else solves a problem with the info. I actually haven’t put it back on yet. I’ve got the Predator mount in front, sputhe in the rear and I haven’t had any issues in the last week.
Old Jun 28, 2018 | 09:30 PM
bigbadpoppa's Avatar
bigbadpoppa
just a gimmick boys. you have race bikes off the line that dont run fork braces that take on extreme track conditions. yamaha r1, cbr1000rr, 1299 ducs etc...the list goes on. if fork braces were that essential, you would see it more standard on high performing motorcycles.
save your money for some better tires and gas.
Old Jun 28, 2018 | 09:44 PM
fxdx1985's Avatar
fxdx1985
This is super lame, but whether it works or not, I like it as an aestethic piece. I hate that unused space under the triple tree. I like to balance it out visually with top triple tree, bottom triple tree, then fork brace. That’s why I went with the cheapy one and not the $200+ piece. But, I got what I paid for right? Haha
