Handlebar swap now issues code b1006
Old Jun 26, 2018 | 12:37 AM
6's7's's Avatar
6's7's
1st Gear
Default Handlebar swap now issues code b1006
Swapped out my handlebars fired the bike up ran to the gas station filled up and went to start the bike and hit the start button and killed power to everything. Found out i had a bad cell in my battery. Replaced the battery and ride the bike for about 20 minutes and the exhaust made a loud pop them the idle rose and wouldn't drop. Started it up again and it rode around and the same thing happened error code b1006 accessory line overvoltage. I've checked stator and rectifier both checked out fine. Has this issue ever happen top anyone on here ? I know it could be multiple things but if anyone has had similar issues let me know plesse . All grounds are tight and the bike has2000 miles.
Old Jun 26, 2018 | 01:03 AM
Yamaharley's Avatar
Yamaharley
I would check your work wiring the handlebars. 9 times out of 10 when you put a new part on and have a problem, its the work that was done causing it. If you turn the bars lock to lock does it make intermittent conections?
rebel7
Jun 24, 2019 01:03 PM
DanTheBetterMan
Aug 25, 2015 04:00 PM
Romprunner714
Oct 12, 2013 11:08 AM
lkohan7373
May 6, 2011 02:14 AM
DaBluzDude
Apr 25, 2006 08:07 PM
