2014 Street Bob Error Codes
Old Jul 2, 2018 | 09:37 AM
killersdd's Avatar
killersdd
Default 2014 Street Bob Error Codes
Hey guys. I've recently acquired a 2014 Street Bob and noticed the check engine light and security light (bike does not have a security system) were coming on intermittently during my last ride. I recently changed the bars back to stock and I have a feeling this is the root of the problem since it didn't occur prior to swapping the bars. The previous owner had installed Z bars, which I did not care for, so I changed them back to stock. While installing the Z bars, the previous owner cut and resoldered the end of the wires for the right hand control module. I believe this is what is causing the problem. My plan is to cut the wires just beyond the solder joints, crimp new terminals on the wires and install a new JAE MX19 female end. I have pulled the following codes: U0001, U0140, U0141, U0142, and U0156. Is there anything else I should check that could be causing this problem? I appreciate your help with this.
Old Jul 8, 2018 | 08:53 PM
killersdd's Avatar
killersdd
Fixed! Shitty soldered splice by previous owner. Cut out the spliced wire (about 2" from connector), crimped new ends on the wire, and pushed the wires into a new JAE MX 19 female connector. Plugged in the new connector and I've done everything but turn the bike upside down trying to force another code. No more codes thankfully. I believe she's good to go.
Old Jul 8, 2018 | 08:54 PM
killersdd's Avatar
killersdd
I double posted this, but if it helps someone else run down a similar problem its worth it.
killersdd
Electrical/Lighting/Alarm
Sep 17, 2018 09:48 PM
FATKEVIN
Oct 25, 2014 08:33 AM
SmittyFXDL
Oct 24, 2012 07:43 PM
pshaw09
Feb 18, 2012 05:06 PM
TOMMY M
Aug 27, 2009 06:07 AM
