Dumb Question...
Old Jul 3, 2018 | 04:45 PM
TinCupChalice's Avatar
TinCupChalice
I've owned more sport bikes and track bikes than I have HD's. I can both upshift and downshift without using the clutch on them. It's all about timing, coordination, and rev matching when you do it, both up and down.
On my HD's? I use the clutch lever
You can preload the shift peg and it will take just a quick stab at the lever for smooth shifting, on both upshifts and downshifts with an HD. But, in the long term, use the clutch...
Old Jul 3, 2018 | 04:46 PM
Kingglide549's Avatar
Kingglide549
Big semi trucks are shifted without using the clutch- they are big slow turning engines, yes even slower then Harley.
Some will double clutch-same difference esp if shifting dwn to get the main shaft up to speed.
The gears are truly big in the transmissions and makes it quite a bit more EZ.
Here is the trick which is imposable to do with any M/C transmission I know of-
As you go up a gear or dwn a gear the driver matches what the RPM will be as if the gear is already selected- AS they do through NEUTRAL!
Thats the key,- and there is no way to do that with a M/C trans.
All you are doing is slamming it in gear.
In a BIG truck, if you use the clutch and manage to get into gear without the rpm matched, you will be in for a very expensive surprise.
What you SHOULD be doing is using the clutch and accelerator together when shifting down.
When shifting dwn you rev the engine to match the next gear so your rear tire is not trying to brake or chirp.
However -like said- you may do it any way you wish.
Its your money.
Old Jul 3, 2018 | 04:56 PM
MMH's Avatar
MMH
Its your money.
The comparison to big trucks is irrelevant. Until very recently, ALL big truck (cl. 7 & 8) had non-synchronized transmissions. If you did not rev match AND double clutch, you would tear up the transmission in no time. Although most big truck today still have non-sync transmissions, there are progressively more that are not only synchronized but in fact are true dual clutch transmissions (no manual clutch).
Why is it imposiible to rev match w/ a motorcycle transmission (or any other transmission)?
Old Jul 3, 2018 | 05:03 PM
Kingglide549
because you CANT GO THROUGH NATURAL
I have A FEELING YOU KNOW MORE THEN ALL OF US
Old Jul 3, 2018 | 06:18 PM
MMH's Avatar
MMH
Oh wait, as long as we are making irrelevant comparisons, I forgot to ask, how does a harley transmission compare to a hydrostat transmission? How do they even work w/ no clutches?
Old Jul 3, 2018 | 06:25 PM
Kingglide549
MMH
You are an arsshole
Go shift you freekin thing anyway you want.
if you want more lessons on how things work take a class
.We all did our best with you
<iframe width="821" height="462" src="https://www.youtube.com/embed/W9LXG7rPQfE" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
https://duckduckgo.com/?q=funny+transmission+commercial&atb=v99-2_g&ia=videos&iax=videos&iai=W9LXG7rPQfE
JohnMn's Avatar
JohnMn
Originally Posted by MMH
Is there something different on the this transmission/clutch (as compared to any other wet clutch motorcycle transmission) where by doing so, it is bad?
No.
It's simple really,, your quoting the manual.
There is no motorcycle manufacturer of clutch driven motorcycles that recommends you "not" use the clutch while shifting.(period)
Do Harley owners understand engine RPM and tranny sync, Yes.
Do Harley owners "speed shift", Some do,, Some don't.
Do Harley owners expect the MOCO to recommend in writing that it's OK to abuse their clutch system and transmission gears by not using the clutch? No.
Do all motorcycle owners that read manuals even grasp this concept?(?)(?)
Get it? , , So that's why they're ganging on ya dude.
With this being your first Harley,, keep in mind that the olde V-twin big jug engine is/and has,, a different performance and load gear ratio.
Hint;
Don't tell your dealer or repair shop about your non-clutch use admission as in this topic.
p.s. And kickin it down,, sounds cool,, but that's about the worst,, and will **** off the neighbors,, yeah,, it's a Harley,, they know that,, have respect.
Old Jul 3, 2018 | 06:49 PM
NORTY FLATZ's Avatar
NORTY FLATZ
MikeR1, MikeR1, to the white courtesy phone please!
Old Jul 3, 2018 | 08:08 PM
cggorman's Avatar
cggorman
OP, you're asking for advice about a technique that nobody here uses. Maybe 1/1000. I don't think we can provide any meaningful prediction about long term durability. Therefore, "better safe than sorry".
There ARE reports of broken shifter pawls, so our trannys aren't bulletproof.
End the end it comes down to your risk tolerance and pocketbook. If you don't mind being the guinea pig and footing the bill for a repair, why not. If the idea of a trans rebuild puts you off, play it safe.
Old Jul 3, 2018 | 08:40 PM
Tommy C's Avatar
Tommy C
What would Bert Baker do???
