Pinging at times
Old Jul 4, 2018 | 04:29 PM
Diesel2's Avatar
Diesel2
Default Pinging at times
Would putting one colder heat range spark plug in help?
Would it help cut back the pinging when I get on it or help reduce it?
My bike is s 2007 Dyna Low Rider
Thanks in advance.
Old Jul 4, 2018 | 04:40 PM
k-weaver's Avatar
k-weaver
Need more info on the bike. I.E. whats been done to it, what tuner do you have, who tuned it. If the bike is stock run a higher octane fuel. If already running high octane, don't lug the motor. Drop a gear and i'll probably go away.
Old Jul 4, 2018 | 09:14 PM
JohnMn's Avatar
JohnMn
Have you tried non-oxy high octane fuel?
Old Jul 4, 2018 | 11:00 PM
F86's Avatar
F86
My pinging culprit seemed to be carbon buildup, effectively raising the compression ratio. I ended up taking it apart (although I tried colder plugs first, as well as different fuels and less spark advance)... It doesn't ping anymore!
Old Jul 4, 2018 | 11:07 PM
Iceman24's Avatar
Iceman24
What fuel are you running?
Old Jul 4, 2018 | 11:35 PM
Tommy C's Avatar
Tommy C
Might be running too lean. A dyno tune may be in order.
Old Jul 5, 2018 | 12:52 PM
srshaw's Avatar
srshaw
Can't aftermarket plug leads disable the Anti knock sensors and lead to pinging? Could be worth a look if they've been fitted.
Old Jul 5, 2018 | 01:00 PM
Pantera99's Avatar
Pantera99
I suspect Im getting carbon buildup. What are u doing to prevent it from happening again? Seafoam? Octane booster? Mostly 6th gear on the highway.
blackxpress
21
Jul 1, 2017 09:36 AM
customsoftail200
Jul 1, 2012 08:05 AM
brino
EVO
Sep 22, 2010 11:09 PM
russl179
Mar 24, 2008 06:47 PM
norfolk88
Aug 27, 2007 06:13 PM
