currently using the screaming eagle stage 1 breather but want to find one that sticks out as far as stock, also uses the stock cover. This is the anniversary model, tried putting the stock cleaner back on but seems to run hot. Any ideas?
HD has a kit P/N 29400239 S/E High Flow Kit (about $160.00). But the original air cleaner cover going back on is questionable, look on E-bay for an oval air cleaner cover. The engine heat is a result of the EPA mandates of a run lean engine. If you have 02 sensors try adding some XIEDS to richen up the mix a little and this helps in cooling down the engine temps. Good luck.
All of our A/Cs come with an External Breather System, allowing your bike to only breathe cool, clean air. This will help with cooling and increase performance and engine longevity. Your bike will thank you!
Here's a REPORT LINK on why External Breather Systems are so important with pics and dyno charts.
And just because Harley's run too hot for their own good anyways, here's a REPORT LINK on other things you can do that will help with cooling your engine.
