Drive Belt Tracking
Old Jul 31, 2018 | 09:55 PM
vessel's Avatar
vessel
Default Drive Belt Tracking
I put a new drive belt on my 98 dyna and rotated the tire and noticed that the belt does not track in the center of the front pulley . I put it in the center of the pulley and after a few rotations it pulls right up close next to the engine side. I don't know if this is normal i never checked where the last belt tracked on the front pulley. I am trying to see if it is rubbing up against anything that close to the engine. any help would be appreciated
Old Jul 31, 2018 | 10:03 PM
Kingglide549's Avatar
Kingglide549
Probably your rear wheel is not centered correctly.
I do not speak Dyna fluently -but that usually is the problem.
One side the axle is too far ahead or to the rear (slightly)
Old Aug 1, 2018 | 10:02 AM
crusader1xxx's Avatar
crusader1xxx
What he said, belt is out of alignment....
Old Aug 1, 2018 | 10:14 AM
Jay Guild's Avatar
Jay Guild
Hopefully it is the rear axle alignment as the alternative is the main drive shaft is bent.
Old Aug 1, 2018 | 10:19 AM
Uncle Larry's Avatar
Uncle Larry
It's not the main shaft ... spin the wheel backwards and see if the belt tracks in the opposite direction ... tweak the adjusters to get it as centered as possible
Old Aug 1, 2018 | 10:30 AM
multihdrdr's Avatar
multihdrdr
Look at the existing wear pattern on the Front Sprocket ... same spot the new belt is running?
Old Aug 1, 2018 | 10:47 AM
stixvrad's Avatar
stixvrad
I think of the main shaft were bent the pulley would orbit causing the belt to be loose then tight as the orbiting pulley move toward the rear wheel and away 180 degrees later.
Old Aug 1, 2018 | 11:48 AM
dyna rider's Avatar
dyna rider
Default Rear Wheel Tracking
I don't know if your bike has it but my 06 dyna has little holes in the rear swing arm. It is easy to take a wire coat hanger and cut off a section about 6 inches long. Then bend one end of it 90 degrees about 1/4 inch long. Then measure both sides to see if they are even. I put a tiny o-ring on my piece of coat hanger to indicate where the center of the axle actually is, and then go to the other side and check for the same dimension. If they are not the same, bring the shorter side further back to match the other. I know I will catch flack on this forum for saying this but, the belt should be tight enough that you can grab it and deflect it no more than 45 degrees. If you can't deflect it that far, it's too tight...If you can deflect it more, then it's too loose.
Most of the guys here will say you need to buy the HD tool to check the belt tension, and if you want a nifty new tool, by all means buy it. I have always done it by my prescribed method and never had a problem. If you put anti-seize on the axle when it was off the bike, you don't ever need to loosen the belt tensioners again to get the axle out of the swing arm.
Old Aug 1, 2018 | 09:06 PM
archergodwin's Avatar
archergodwin
If, after you align your rear wheel, it still runs off to one side of the front pulley... I say, no big deal.
Old Oct 7, 2018 | 02:14 PM
Jim8208's Avatar
Jim8208
I've got an 07 dyna and have the same little holes in the rear swing arm as yours. I did the exact same thing to measure and make sure the axle was the same distant between holes on both sides using a cutoff piece of coat hanger and o-ring like you did. I tightened the belt to spec and no matter what I do the belt still tracks right. I can rotate the tire rearwards and it still tracks right. I'm stumped as to how to get this belt to track true. It was tracking true before I removed the rear wheel for a tire change. Any suggestions would be greatly appreciated?
