2006 Dyna Died while riding?
Old Aug 28, 2018 | 10:08 PM
hAkron's Avatar
hAkron
Default 2006 Dyna Died while riding?
My Dyna died on the highway today. It’s for sure an electrical issue. It’s acting like a bad batter. I just got it towed home so I haven’t started troubleshooting yet. Could it be a bad stator? I pulled the stator roter a few years ago while I had the primary apart for other stuff (IPB and switching back to mid mount controls) and I had a guy weld the bolts, so I don’t expect it to be a chewed up stator (as can happen with the unmodified ‘06 dynas), but before I get into the primary, what is a realistic lifespan on a stator? I have less than 20k miles on this particular bike.
other things I’ll check are the battery (but doubtful since the bike died in motion) and look for anything shorting out.
Any advice is welcome.
Old Aug 29, 2018 | 01:58 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
HD had a known issue with the ignition switches on those model bikes. I'd start with that.
Old Aug 29, 2018 | 12:01 PM
hAkron's Avatar
hAkron
I had the battery on a trickle charger all night and it's still flashing, so the battery doesn't seem to be taking a charge. When I turn the key, I get lights, but hitting the starter button just gives me a little bit of chatter from the starter motor and that's it. This battery is only 2 years old, but I got it from Autozone, and I hear their batteries are not the best.
After that, I'll check the voltage regulator, stator, and the ignition switch and see what's what.
Old Aug 29, 2018 | 12:32 PM
nevil's Avatar
nevil
The battery sounds like its toast. Put a DVM on the terminals and see what the reading is. The best thing would be to get it load tested and if it fails get a new one. When you install the new one check the connection of the ground cable. In fact, check the ground connection first, it could be the problem.
Old Sep 4, 2018 | 09:45 AM
hAkron's Avatar
hAkron
There was some corrosion on the positive battery cable. Once I got the battery out of the bike, it started charging just fine. I'd already bought a new battery, and so I installed it in the bike. I'm suspicious about the AutoZone Battery, which is only 2 years old, but just in case. The new battery is working fine. My Dakota Digital speedo has a volt meter on it. I left the bike 'on' (headlight on, but engine off) and watched the battery draw down for a little bit, then I started the engine and it go back up to 13.3, so it looks like that charging system is functional.
Old Sep 4, 2018 | 12:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
As a rule of thumb, prior to a new battery going into my any of my bikes I put an overnight charge on it using my smart tender charger. Harleys electrics run on the batteries any time you are operating the bike, the charging system tries to maintain the batteries full charge thru the regulator. Start your bike after completing a full charge then test the voltage out put to the battery while the bike is running, the voltage should be 14.2-14.5v .
Dominic Catanese
Electrical/Lighting/Alarm
Apr 23, 2019 10:36 AM
Jsin23
Oct 8, 2018 04:59 PM
voudoujoe
15
Aug 24, 2016 03:07 PM
rmtwrx
Apr 25, 2016 11:49 AM
thebamaguy
EVO
May 18, 2011 03:21 PM
