Electrical issue
Old Apr 21, 2019 | 05:50 PM
Dominic Catanese's Avatar
Dominic Catanese
2nd Gear
Default Electrical issue
2006 Dyna that rode fine for 65 miles. Went to restart and it just clicked. Jumped it and ran fine for about 15 minutes, then throttle response went haywire and battery started dying. Has a new stator and battery in it. Could it be the voltage regulator?
Old Apr 22, 2019 | 05:30 AM
nhrider1's Avatar
nhrider1
Yes it could be. Best way to check the regulator is to get the bike running and measure the battery voltage. A good v/r should read between 13.0V and 14.7V and increase with rpms.
Old Apr 22, 2019 | 01:12 PM
nevil's Avatar
nevil
Could also be your battery connections, so check the ones at the terminals and the ground cable on top of the starter.
Old Apr 22, 2019 | 05:57 PM
Vernal's Avatar
Vernal
I don't know about the Dynas but on our touring bikes the large connection on the starter is a battery positive and the ground is located under the starter and connected to the transmission.
Old Apr 22, 2019 | 08:33 PM
nevil's Avatar
nevil
The OP and I have the same setup. Checking that ground strap connection is part of my usual routine. I didn't know that it was different on the touring bikes but it's good to have that info.
Old Apr 23, 2019 | 10:36 AM
skinman13's Avatar
skinman13
I have seen this many times in cars and trucks and airplanes. A bad stator or voltage regulator or battery can compromise the entire system setting up future failures. A bad stator can damage the voltage regulator and it may fail at any time. Also, it is not uncommon for voltage regulators to become thermally intermittent before they fail. You replaced the stator and battery, now change the voltage regulator. The only thing left is the fuse, switch, and wiring.
Weeboy1
Engine Mechanical Topics
Apr 23, 2017 05:37 AM
Mchlumsky
Dec 27, 2016 11:29 AM
WOLFE1584
Apr 12, 2015 10:45 PM
Nautilus
EVO
16
Nov 10, 2010 07:28 AM
Dustmaker
Sep 22, 2008 10:13 PM
