Oil leak while on Sidestand
46K
tons of exterior mods, powertrain is stock w/stage one
Over the winter the bike was sitting upright on my table lift. Been riding it all summer and just this past week (was sitting off the lift on its side stand, while on vacation w/family) I came home to notice a small amount of oil on the floor under the bike. I can't see where it is coming from and all around the primary/pulley its dry. No where I touch its wet. At first I thought maybe trans fluid but its not (i use spectro which is green in color) this is oil ....Nothing is over filled and its only been since sitting for a week on the side stand....
Just wondering on a 2012 what it might be...I heard the mainshaft bearing can walk and cause a leak but I thought that was earlier year bikes....
Anyone have any idea's? of where I should be looking? going to be a winter project if I have to tear into the primary but thought id ask first...
Other things I looked at were inner primary O rings, (replaced) stator plug, and a loose primary drain plug. All to find the "leak spot". Something else I was torn about was the amount of primary oil to use. (I only use a qt) No matter what the manual calls for my Indy says never to fill to the bottom of the derby cover like some manuals call for. Only fill about a 1/2 inch up the clutch and no more. Transmission vent was also looked at to make sure it wasn't plugged. Hope this helps some.
I have an oil cooler but the lines are dry, oil filter itself is dry but I can’t get my finger under the bottom to see if it# the filter.
I’m doing an oil change this week so I’ll clean it up, replace the filter and hopefully that will cure it.
i checked the stator plug area and it seemed dry....
anything else up front that might cause an oil leak?
