2001 dyna no start issue...please help.
Old Sep 9, 2018 | 09:50 AM
xXRaptorXx's Avatar
xXRaptorXx
Stage IV
Default 2001 dyna no start issue...please help.
Hey guys. New to forum. This is killing me. Having an issue with my 2001 dyna wide glide. Its was running great until i noticed i needed brakes. It was late so there was nothing i could do about that so i figured i would hook up the new engine LEDs i recently purchased. I did all that and put it up for the night. Got my brake pads and installed them. Went to go for a ride and now she wont start!! Im not getting spark to the plugs. Im getting power to the center pin of the coil plug. Could it be that the CDI is bad or will disconnecting the battery activate the security (which i dont have the fob for yet)and cut power from the ignition system. It will Roll over but not fire at all. Please help.
Old Sep 9, 2018 | 09:55 AM
TattoodCaptain's Avatar
TattoodCaptain
I had that happen on my 99 dyna, just turning over with no fire. It turned out to be the crank position sensor.
Old Sep 9, 2018 | 09:58 AM
xXRaptorXx's Avatar
xXRaptorXx
Stage IV
will that not cause it to not get spark??
Old Sep 9, 2018 | 10:04 AM
TattoodCaptain
I wasn't getting spark and tested my coil, which was good. The flash fault code said the crank position sensor and sure as ****, it fired right up after replacing it.
Old Sep 9, 2018 | 11:12 AM
crusader1xxx's Avatar
crusader1xxx
I know it sounds like something you did, but it’s probably a coincidence....
I know your thinking spark, but are you getting fuel to the carb? Need both to fire up....
Old Sep 9, 2018 | 04:59 PM
xXRaptorXx's Avatar
xXRaptorXx
Stage IV
Bro you are a life saver!!!!! Ran down to the Harley dealer and grabbed a new CPS and with a few choice words while routing the wire.....lol....it fired right up!! Thanks alot for the help!
Old Sep 9, 2018 | 05:03 PM
xXRaptorXx's Avatar
xXRaptorXx
Stage IV
oh there was PLENTY of gas. The fumed were killin me. Lol. Turned out the be the crank position sensor like TattoodCaptain said. Now im back in the wind. Thanks for posting though.
Old Sep 9, 2018 | 06:17 PM
TattoodCaptain
Hell yeah! Glad it worked out .Twist that throttle for me lol, I'm stuck on the damn boat
Old Apr 16, 2019 | 04:18 PM
ajames01r's Avatar
ajames01r
Going through the same issue with my 1999 FXD. Narrowed it down to the CPS as well. Did you have to re-use your old plug?
Remington.870
Dyna Models
Dec 18, 2019 07:05 PM
francisstark1
Exhaust System Topics
Jun 8, 2012 11:18 PM
Chap
Apr 22, 2012 09:26 AM
Proudtexan
Dec 29, 2010 05:51 PM
93dynachris
Jul 13, 2010 11:26 AM
