1-assure you have 12.6 Batt voltage
Losen and tighten your connection at battery and at the ground,
VERY important!
It is best to take the bolt out and scrub the area with a wire brush and at the frame, put in a stainless bolt.
2-with your test light or meter chase the wires until you run out of the voltage
FXR's use circuit breakers, not fuses. They are located behind the left side cover below the seat. Before you start digging in, check the basics Kinggide posted & work from there. If your not sure of what you are doing enlist the services of someone that does.....
