Help with tail light wires
Old Sep 30, 2018 | 02:16 PM
Dougiewhite's Avatar
Dougiewhite
Stage II
Default Help with tail light wires
I have a 04 dyna wide glide. Had to relocate rear turn signals for hard bags.got a led strip for new turn signals. It wrks fine on test battery. I hook it up to the purple an black wires that went to old signals an it wrks for a second an then flashes like the hazards lights r activated. I assume the black is ground an the purple on each side is the hot. Am i crazy
Old Sep 30, 2018 | 06:59 PM
lookn4sun's Avatar
lookn4sun
Yeah, the purple is probably your hot. If I'm not mistaken with those LED's, on the turn signals at least, you have to add a load balancer. You're losing a lot of amps on the circuit, and it will flash really fast.
Old Sep 30, 2018 | 07:23 PM
Dougiewhite
Stage II
Thanks for ur help. Got fed up an trashed the led an order small bullet lights instead with standard bulbs.
fatboy1729
Jun 12, 2013 11:14 AM
huskytamer
May 9, 2012 02:30 PM
ironmike666
Nov 28, 2011 06:19 PM
hogwild72
Mar 6, 2008 03:04 AM
Angry_Monkey
Apr 21, 2007 12:24 PM
