Easybrackets for 07 ?
Old Jul 3, 2007 | 04:09 AM
matkiwi's Avatar
matkiwi
Default Easybrackets for 07 ?
Has anyone used Easybrackets (http://www.easybrackets.com/) on an 07, pref a Bob ... I bought a set for mine and had to modify them with a Dremel to fit ... so they no longer come off. I bought the ones I thought should fit but they were nearly an inch out. If you have fit a pair I'd really appreciate the part number and, as confirmation, the measurement between the holes.
Thanks, Mat
Old Jul 3, 2007 | 01:49 PM
98fxd's Avatar
98fxd
Default RE: Easybrackets for 07 ?
put mine on an 07 bob, no problems what so ever. no modification, nothing. on and off easily. i bought the set for an 06 dyna, part no DNA-L2
Old Jul 3, 2007 | 01:51 PM
Trout's Avatar
Trout
Use BareBacks instead. I have a set and LOVE them. There is no bracket involved, so you don't have to worry about distance between the holes. The price is comparable to Easy Brackets. As long as your strut holes are 3/8", they will work great. The set I bought wasn't even listed for a Dyna, and they work great (the difference between part numbers is just bolt length. The set I bought was for a Heritage, so the bolts were a little long, but nothing a spacer didn't fix). I've used them with fully loaded bags on about 2500 miles worth of trips so far. No issues. They also don't rattle with empty bags, like many complain that the Ghost Brackets and Easy Brackets do.
Old Jul 3, 2007 | 02:15 PM
wideglidebob's Avatar
wideglidebob
amen my easy brackets rattle so bad at first i thought i had a rod going out, i called them and they said first we have heard of that try putting a washer to offset the bolts tried and diden`t work , they are grap
Old Jul 3, 2007 | 04:35 PM
matkiwi's Avatar
matkiwi
Interesting search results looking for Barebacks ! [:@] They look pretty good ... I might try them ... thanks
Old Jul 4, 2007 | 02:09 AM
ctsbob's Avatar
ctsbob
Whoa..make sure the google search for barebacks includes HARLEY !!
damager1
Jul 6, 2015 12:00 PM
bjindra
Aug 10, 2013 07:26 PM
warren888
Jun 13, 2007 11:15 PM
98fxd
May 30, 2007 09:22 AM
