What would cause rear cylinder foul out
Old Nov 22, 2018 | 05:16 PM
SmittyFXDL's Avatar
SmittyFXDL
Default What would cause rear cylinder foul out
My 04 dyna was running great until this afternoon. Gassed up with 87 non ethanol and ran good for 15 miles then ran sluggish and sounded like it was in and off one cylinder. Pulled plugs and rear one was fouled and smelled like gas. Pic below.
any idea where to go from here and what it could be? Thanks in advance.
Front looks good rear looks bad
Old Nov 22, 2018 | 05:47 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Pull both plugs outta the head, attach cables to plugs and ground the plug ends to the engine. Observe spark. Switch the position of the cables, if one does not spark. Might just need a new coil and spark plug cables.
Old Nov 22, 2018 | 06:24 PM
SmittyFXDL's Avatar
SmittyFXDL
*********just swapped coil and plug wires and still gas foul on rear plug. *************
what is next step?
Just tried 3 sets of plug wires. Not getting consistent spark front or rear. But only rear getting gas fouled.??? Anyway to test coil and make sure that's the culprit?
Last edited by SmittyFXDL; Nov 22, 2018 at 06:47 PM. Reason: Updated info coil swap
Old Nov 22, 2018 | 07:10 PM
REW13's Avatar
REW13
Coil would have been my first guess.
What riding conditions are you doing? Many years ago I had a sporty and it would do that on slow riding conditions, like heavy stop and go traffic I used to carry several plugs with me when I used to go to Myrtle Beach for a night rideand a ride too.
Old Nov 22, 2018 | 07:35 PM
fxdlx's Avatar
fxdlx
Why would you run 87,(unless that's all that was available) what does the owners manual say to use.
Old Nov 22, 2018 | 07:44 PM
SmittyFXDL's Avatar
SmittyFXDL
Was only option available. Since it was non ethanol i didn't think it would be that bad. If it was a gas issue wouldn't that affect both plugs/ cylinders?
Old Nov 22, 2018 | 08:41 PM
SmittyFXDL's Avatar
SmittyFXDL
Swapped coil and plug wires and still rear plug fouling. Tried spraying wd40 around the intake manifold and didn't notice any change in engine idle. Running out of options. Anything else it could be?
Old Nov 22, 2018 | 08:44 PM
TwiZted Biker's Avatar
TwiZted Biker
Time for a compression test.
Old Nov 22, 2018 | 10:29 PM
John CC's Avatar
John CC
Did you swap the plugs? If you've swapped the plugs, plug wires, and coils, then either it's the ECM or it's not spark related.
Old Nov 23, 2018 | 12:03 AM
fxdlx's Avatar
fxdlx
Are you injected or carbed
