Rear Shock Setting
Old Jul 3, 2007 | 01:43 PM
wfdmedic8's Avatar
wfdmedic8
Default Rear Shock Setting
I'm looking for any info on setting my rear shocks. Does anyone know the stock setting, and what weight is that setting for. I'm 205 and I seem to bottom out more then I would like, not to mention when the GF is along for the ride.
Old Jul 3, 2007 | 01:54 PM
sleepneagle's Avatar
sleepneagle
Default RE: Rear Shock Setting
measure the shock at static rest upright. Now sit on the bike and measure again. There should be 3/4 to 1 inch compression. Adjust the same for two up riding.
Old Jul 3, 2007 | 09:30 PM
madden23's Avatar
madden23
On a 1-5 preload, they come stock set at three. Shocks are pretty easy to change, upgrade.
Old Jul 3, 2007 | 10:10 PM
sabby48's Avatar
sabby48
im 260 and i left mine at 3 they seem to be fine 06 fxdci
Old Jul 4, 2007 | 07:10 AM
tbone52's Avatar
tbone52
Mine was on 2 when I got it. With the wife on it would bottom out. Solo was springy and jumped in corners. I went to 4 and the wife complained of bumps transmitted directly to her back side. I noticed it no longer jumped in corners and was throwing me off seat on the pressure ridges on the road. I put it on 3 and that seems to be a good compromise between taking bumps and not jumping in corners. I'm 206 and the wife is, well, less.
Old Jul 4, 2007 | 07:13 AM
Gadgetech's Avatar
Gadgetech
My original shocks had to be set all the way to 5 to keep from bottoming out. I only weigh 220 so I think they were crap myself. I put progressive 412s on and the bike handles so much better.
Old Jul 4, 2007 | 02:31 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
that's what soo nice about dynas, easy to adjust, if you have a spanner wrench or adjustment tool. if 1 is the softest then 5 will be the firmest. i think with two up you will be fine with it set at three, if to firm maybe two also adjustrear tire for two up, don't forget to put tire back to solo pressure for one rider. i've also put 10w fork oil up front. it put the GLIDE back in superglide.
donanderson
Jun 26, 2024 08:47 AM
Keithhu
Jul 22, 2014 10:21 AM
troop
Nov 28, 2012 01:05 PM
actionmotor
May 1, 2009 04:06 AM
DraftDancer
Jan 21, 2006 01:35 AM
