clutch cable
Old Jul 3, 2007 | 09:18 PM
bikerdog134's Avatar
bikerdog134
Default clutch cable
changed to buckhorns on my 05 dynaglide.i want to add sone pullback risers and will have to use a longer clutch cable. how hard is it to change ?any advice would be appreciated.thanks
Old Jul 3, 2007 | 10:06 PM
DYNAMITE 1's Avatar
DYNAMITE 1
Default RE: clutch cable
Just changed mine 2 times (long story) [:@]It is pretty simple. Mines an 07 wide glide so dont know how different they are. Drain oil from tranny, should be about 1 quart ? if more comes out you drained somthing else. Remove 6 screws from side with cable going in to it. Cable should come off with cover. nothing on the engine needs messed with. Remove large C clip holding the piece that the cable is atatched to.Its easier with 2 people youl see why. Dont lose the parts as everything inside will now be loose, top plate, 3 ball berings and bottom plate. Pretty sure it only goes 1 way but pay att. to how stuff goes. Unscrew cable, atatch new cable, check o ring on new cable. Reverse procedure, use lock tite on 6 screws, fill with oil check your manuel, mine was 1 quart exactly 75-100 gear oil. Ckeck for leaks, enjoy
wideglideCVO
Engine Mechanical Topics
Mar 21, 2022 09:15 AM
cdn.biker
May 11, 2018 03:15 PM
bdjhog
Jun 14, 2011 11:41 PM
n0code
Sep 2, 2010 11:47 PM
Bearcat1
Apr 27, 2010 04:01 PM
