Totaled fxdl engine fitting
Old Dec 19, 2018 | 02:30 AM
Scootertooter's Avatar
Scootertooter
Stage II
Default Totaled fxdl engine fitting
hey all this is my first post googled my question forever never got a awnser so I’m asking here.
i own a 2007 fxdl was recently totaled has a baker tranny freshly installed it that had less then 50 miles on it before I was hit.
question is will my engine/trans bolt right up to a 2006 dyna since both are 6spd I have cams tuner etc.
on my 96” and was on the road to a 107 build but luck wasn’t on my side unfortunately.
any help would be appreciated buying a 2006 price wise seems smart if doesn’t match I’ll have to figure out something else
thank you!
Old Dec 19, 2018 | 06:15 AM
AFMM3's Avatar
AFMM3
2006 and 2007 both use the same frame. Part # 47463-06BHP "Frame, 29 degree rake".
Old Dec 19, 2018 | 07:38 AM
Scootertooter
Stage II
sweet so I can just swap frames essentially then thank you!
Old Dec 19, 2018 | 07:42 AM
TwiZted Biker's Avatar
TwiZted Biker
Yeah you can do the swap but I'd check with the local DMV about the how to handle the numbers being changed and talk to your insurance agent before you spend money.
Old Dec 19, 2018 | 11:08 AM
Harleywashboy's Avatar
Harleywashboy
Definitely this. The newer bikes are titled by frame, and some states require the numbers on the engine to be part of the title. You'd need the title for the 06 frame, and when you swap everything over, you lose the 07 and now have an 06. There's different rules that vary a lot by state for special constructions and salvage titles, showing receipts, etc. You need to get in touch with the local form of DMV or state troopers office that handles these things.
Old Dec 19, 2018 | 11:34 AM
iaminsider's Avatar
iaminsider
State of MN tracks the engine number in their system for each motorcycle. You just need to file the paperwork to change the engine for a given bike.
Old Dec 19, 2018 | 02:04 PM
TwiZted Biker
Frame & engine numbers have matched on Harley's since 1970, some states can be bit weird about the mixing and matching the numbers game. Even with all the correct paperwork I've had to jump through some ugly hoops on a couple occasions.
Standup303
Sep 6, 2018 09:36 AM
MattDunne
Aug 12, 2018 11:01 PM
ballbreaker69
May 8, 2015 06:45 PM
Nikolaiownz
Feb 2, 2014 11:15 AM
Farout68
Nov 29, 2012 11:42 AM
