2013 Dyna Tanks All Same?
Old Jan 17, 2019 | 02:46 PM
chrison600's Avatar
chrison600
Default 2013 Dyna Tanks All Same?
Hi All,
I have a 2013 Super Glide that I'm using as a basis for a project and was looking to replace the larger, chrome tank console with one of the smaller consoles either from the Wide Glide or Street Bob. I've been running under the assumption that the consoles would fit fine over my existing tank, but wanted to reach out to see if anyone could confirm if all of the tanks are the same...
Chris
Old Jan 17, 2019 | 10:31 PM
Qdog002's Avatar
Qdog002
I doubt they are the same because the Super Glide tank is a 5 gallon tank and I believe a Street Bob tank is 4.7 gallons. If the capacities are different then there is a good chance that how the consoles line up would be different also. A call to your local dealer with the right part numbers might be able to help you better than me.
Old Jan 18, 2019 | 09:12 AM
chrison600's Avatar
chrison600
Looks like you're probably right. The part numbers for the tanks and the FI top plates are different. I'm going to order a Wide Glide/Street Bob top plate and see if it matches the opening in the top of the tank.
Chris
Old Jan 31, 2019 | 12:15 PM
chrison600's Avatar
chrison600
Update: You were correct. A Super Glide (and I think a Fat Bob is the same) tank is not the same as a Wide Glide or Street Bob. The FI top plates are different and the opening for a Wide Glide/Street Bob FI top plate is narrower. I just ordered a very good condition Street Bob tank. Crossing my fingers that it will mount on the frame.
Chris
Old Feb 1, 2019 | 02:47 AM
Rusty19MCSFV's Avatar
Rusty19MCSFV
The tanks themselves are completely swapable and will bolt on. Plugs for the fuel pump, and fuel gauge are the same. The plug for the gauges on the tank may be different. If so, you'll need the harness that comes out of the steering neck, to the gauges for whatever tank you're running. Not the bike it's going on.
Old Feb 1, 2019 | 07:54 AM
chrison600's Avatar
chrison600
Thanks for that. I already have a Street Bob harness. The only difference I can detect is the light bar (signals, etc) is a different shape/size for the different console shape/size.
RexD
Oct 21, 2015 05:56 PM
DéDé1
Oct 9, 2015 01:44 PM
Indy-Pendent
Jul 8, 2015 05:21 PM
nichiowa
Jun 20, 2011 02:18 AM
fhansen
Dec 17, 2009 06:32 AM
