06 6-speed shifter bushing
Old Jan 31, 2019 | 02:33 PM
Snekbitt's Avatar
Snekbitt
Default 06 6-speed shifter bushing
Hey all,
Is the bushing that sits in the middle outer primary replaceable? The one for mid control shifter shaft. If so, does anyone know the p/n? I looked on Ronnies but I'm not 100% on the drawing.
Thanks!
Old Jan 31, 2019 | 03:12 PM
joe40x's Avatar
joe40x
34982-02A is the inner primary...can't find one for the outer. Can you send a pic of what you need?
Old Jan 31, 2019 | 03:18 PM
Snekbitt's Avatar
Snekbitt
The bushing that sits right here. PO had threaded it for some sort of cap. I want to go back to mids, so I will need to replace it before proceeding. Hoping I won't have to replace the whole case.
EDIT: I'm referring to the metal sleeve, not the shifter spacer.
Old Jan 31, 2019 | 03:20 PM
joe40x's Avatar
joe40x
Hummmmmmm, working on it.....
Old Jan 31, 2019 | 03:26 PM
joe40x's Avatar
joe40x
SWAG ( Scientific wild *** guess) 33708-94A?
Old Jan 31, 2019 | 03:33 PM
Snekbitt's Avatar
Snekbitt
Based on Ronnie's
http://partsfinder.onlinemicrofiche....CASE%20HOUSING
My closest guess was item 20. 60798-06. But I have no idea what 2. 791A is that follows it. Should be the shifter assembly? I see 2 791A is also the bolt for the chain tensioner. Something just ain't adding up with that.
Old Jan 31, 2019 | 09:28 PM
crusader1xxx's Avatar
crusader1xxx
34982-02a?
Old Feb 1, 2019 | 10:24 AM
Snekbitt's Avatar
Snekbitt
Crusader, based on this thread, I think you may be correct.
https://www.hdforums.com/forum/dyna-...ids-mod-5.html
fasteddie
Jul 30, 2024 08:20 AM
hardheaded
Jan 28, 2019 03:21 PM
prplglide
Sep 6, 2013 09:12 AM
MichiganRider
Dec 24, 2012 04:43 PM
zubaugh
Apr 26, 2008 01:25 PM
