So what is it with the derby cover bolts? Changed my Primary fluid over the weekend. I've seen a few threads and heard of a few guys that have had problems with these and stripping the heads. I always use a torque wrench, never bring it to the top of the range and have quality tools but yet if your not really careful these little suckers can strip the heads easily (I am using the supplied bolts from Harley).
So the question is this...I'm looking to replace the bolts with something of a little higher quality but was wondering what everyone's thoughts are on using stainless steel bolts for the job. Typically with stainless steel you'd want to use a bit of anti-seize but of course everything on a Harley needs a little thread locker and so there is my dilemma.... Does anyone recommend stainless steel and what do you use on the threads or should I just go with another set of chrome bolts? And is there a brand recommended?
Thanks, Steve
I swapped the oem bolts on my 14' Fat Bob at 1k miles back in 2014. I used stainless allen button head bolts with stainless washers. No thread locker, no antiseize. No issues in about 5 years. Primary gets opened and the fluid changed every year.
I can't stand torx bolts and try to eliminate them as much as possible.
I never use a torq. wrench now on these bolts since I stripped a couple first time I had the cover off. You can tell by 'feel' when the bolt is tight enough, always use blue 'loctite' too...b.
LOL! Search it, if you want, for my rambling galvanic corrosion/galling/loctite/anti-sieze posts.
I use ARP stainless (WAY overkill, but pretty) and blue loctite on this type of thing. Torqued to the FSM recommended value (100 in-lb?) Never had a problem with damaged/loose fasteners or covers.
The leading cause of grief with these screws is people using a T25 driver instead of the correct tool which is a T27.
Many Torx socket sets do not come with a T27 , when that is the case the T27 must be purchased separately.
Torque wrench ? . yes always.
Loctite ? ..no , when torqued correctly it's not required
My T27 was too big! So I had to use the T25. I have found that on a few places and I have multiple "T" drivers and tried them all. Of course not all tools are created equal, some fit better than others.
