Cut fender struts on frame
Old Feb 10, 2019 | 10:23 PM
dynamedic's Avatar
dynamedic
6th Gear
Originally Posted by Blue Bob
I would cut the radius away both sides and square up the joints and weld prep
Use your fender as a template and start fitting the strut extensions
TIG tac / check fit again / weld and clean up the welds
I would probably quote 3 hrs. Shop rate varies from shop to shop and what part of the country. You may need to shop because some shops will not want to take it on.
I would think you could expect $300 - $350...If I had to fab extensions add another 2 to 3 hrs.
Just remember the cheapest is not always the best. Talk to the shop and make sure they understand exactly what you want \ expect. See if they understand and are confident they can do the job properly
I would not even consider replacing more than just the struts. Chopping the frame? Please don't.
thats about what I was thinking it would cost, that’s the route I’ll end up going probably. And I will not be cutting any more off the frame lol.
ill source a wrecked frame and see if the seller will chop em off. Thanks!!
Old May 19, 2019 | 03:08 PM
**Maitre**'s Avatar
**Maitre**
Stage I
Hi Guys,
my name is Matthias, from Germany. Maybe I´m in the wrong section here: I drive an HD Softail Fatboy from 2007 - the one with the 6 gear. The previous owner cut of the inner fender struts - but I want to replace them and already found one welter in Germany who is specialized on welting frames and do custom bikes. My big problem is, that I have already searching for weeks - really for weeks - to find any way to buy the cut off used struts - but not succesfull. Is there anybody here in the states who can help me? Find someone who have the cut off struts on stock and can ship to Germany? (of course will pay for all). Or do you have any succestion to buy a frame from accident where I can someone cut off the tail with the struts and ship to Germany? ANY help is highly appreciated. And, sorry if my typing may be wrong. Million thanks to the US rides in advance, Matthias
Old May 20, 2019 | 11:50 AM
checkster2000's Avatar
checkster2000
You could try the rocket Bob's rear fender kit. I believe that is designed for 2 up without the struts.
https://shop.rocketbobs.biz/collecti...ant=2635066819
bran48
Mar 16, 2014 11:22 PM
hdmike1969
Mar 13, 2013 05:46 PM
traildog
EVO
Feb 10, 2013 07:41 PM
LugNut88
EVO
Aug 29, 2011 11:48 PM
FirstRealBike
Aug 31, 2008 06:19 PM
