Problem with Flush mount gauge and cap
Old Feb 10, 2019 | 02:01 PM
steel insane's Avatar
steel insane
Default Problem with Flush mount gauge and cap
I put this on a 2006 WideGlide:Flush-Mount Fuel Cap and Gauge Kit
Part Number 62910-06C
Here's the issue. There are 2 o-ring gaskets in this kit. Both appear to be for the fuel cap. One is at least double the thickness of the other one. If I use both, the cap will not sit flush. If I use only one, the cap will close and sit pretty much the way it is supposed to, with the smaller one fitting better. I also don't want gas coming out so it does need to seal properly. The instructions say there's only supposed to be one. Could be a kit assembly error or maybe you are supposed to pick the right one for your bike.
Which one am I supposed to use?
Old Feb 10, 2019 | 02:12 PM
Dynaglide92's Avatar
Dynaglide92
Problem only need one. They put two for possibly different style gas tanks. It won’t leak gas the newer bikes 96-up need to vent
Old Feb 11, 2019 | 04:41 PM
Jay Guild's Avatar
Jay Guild
Did the ring on the fuel gauge come off? There should be one on it to hold it in the housing.
union53
Jun 28, 2019 08:40 PM
cl605nick
Apr 3, 2012 11:35 AM
roadroids
Mar 24, 2011 01:58 PM
Romark
Jan 4, 2010 06:06 PM
Romark
Jan 5, 2009 11:27 AM
