2013 Dyna Wide Glide
Old Mar 6, 2019 | 09:14 AM
Gkarunner's Avatar
Gkarunner
Stage III
Default 2013 Dyna Wide Glide
2013 Dyna Wide Glide misses sputters and will quit while idling. Battery positive post arced and melted. Replaced battery still does the same thing. Have error codes po107, po122, and po641. First one is map sensor open/low, 122 I think has to do with tps sensor, and 641 is 5 volt ref. Out of range. No other codes. Speedometer says lo range. Any help as far as possible fixes short of replacing map sensor and tps sensor. Bike only has about 14000 miles on it. Any help will be appreciated.
Old Mar 6, 2019 | 12:04 PM
nevil's Avatar
nevil
A bad sensor will not melt your battery post. The codes you're getting are sometimes thrown when the ground cable connection to the frame is loose or dirty, so check that if you haven't already. Also try to see if any of the battery cables might be broken inside the sheathing. Not an easy thing to check but sounds more likely that the problem has something to do with the cables.
Old Mar 6, 2019 | 12:11 PM
Gkarunner's Avatar
Gkarunner
Stage III
Ok thanks
mgb1
Feb 16, 2019 06:00 AM
matthew seiller
May 10, 2018 10:32 AM
Jeffdyke
Sep 15, 2017 06:22 PM
gary1hd
Oct 5, 2012 11:07 AM
EZ48
Aug 27, 2009 05:08 PM
