First gear issues
Old Mar 25, 2019 | 09:27 AM
John CC's Avatar
John CC
You say it does it repeatedly. Is it regular? What is the frequency?
Old Mar 25, 2019 | 12:32 PM
2007dyna's Avatar
2007dyna
It will do it every time I’m in first gear. If I very gently twist the the throttle, just enough to get it moving from a dead stop and then shift to second, I can keep it from doing it. But any attempt at quick acceleration in first gear will cause it to happen.
Old Mar 25, 2019 | 12:57 PM
2007dyna's Avatar
2007dyna
And it will keep doing it over and over until I either back off of the throttle or shift to second.
Old Mar 25, 2019 | 01:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by 2007dyna
The guy I bought it from said he had it set up this way intentionally because he “is a small guy and the bike had too much power at take off”.
The seller was giving you a line of BS.
It sounds like a transmission issue.
Old Mar 25, 2019 | 01:15 PM
2007dyna's Avatar
2007dyna
Yeah that’s what I’m thinking. I’m taking it to the shop this week. Thanks for all of the reply’s.
Old Mar 25, 2019 | 05:25 PM
2007dyna's Avatar
2007dyna
Talked to the shop. He can’t get to it until next week. But he seems to think it’s not a transmission problem at all. He said it sounds like a programming issue with the EFI. Guess we’ll find out.
Old Mar 25, 2019 | 07:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Get a helper to help steady the bike in a vertical position, remove the derby cover and check for the correct level of the fluid in the primary case. The level should be just to the bottom of the clutch pak (the big round thing behind the derby cover) . there are warnings and cautions about too much or too little fluid in the owners manuals. You need to demonstrate to the shop what it is doing. I think the shop is after your wallet by mentioning a tune.
Old Mar 25, 2019 | 07:50 PM
Bluesrider.df's Avatar
Bluesrider.df
Old Mar 27, 2019 | 09:50 PM
Max Headflow's Avatar
Max Headflow
The bike has a wet clutch. It will likely jump a little when first going into gear. Make sure the oil level in the primary is correct. You can try holding the clutch in for a few seconds before kicking into gear but the "jolt" has never bothered me.
Old Mar 27, 2019 | 11:15 PM
2007dyna's Avatar
2007dyna
It doesn’t do it just once. It will do it repeatedly until I shift into second.
