Hello again. Been a while but wanted to circle back and let you know that this old post was not the resolution for the problem. I ended up having the injectors updated from the 8 degree injectors to the 25 degree injectors and that was the final solution to the problem. I believe another gentleman had reported this as well. It's been many months of searching and wondering. The new injectors fixed it! Take care.
OP~
Yo might want to check your electrical (ie. fuse) connections again, if you had so much corrosion before. This time, after you've cleaned the contacts, use some di-electric grease to keep them from corroding in the future.
Also, congrats on finding the true culprit. Altho, I don't know why the 8 degree injectors are suddenly no good, after 13 years...
OP~
The company said they showed depreciating performance over long periods and had a service notice to have them replaced with the 25 degree if stuttering started happening.
