2008 Anniversary Wide Glide info
Old Jul 7, 2007 | 10:31 PM
myzen's Avatar
myzen
Default 2008 Anniversary Wide Glide info
Specifications
Insurance:
Request A Quote
Finance:
Apply Now
Shipping:
Ship this Vehicle
Manufacturer:
Harley[/b]-Davidson®
Year:
2008[/b]
Model:
FXDWG Dyna® Wide Glide® 105th Anniversary Edition
Vehicle Type:
Dyna
Price:
Request a Quote
Color:
Copper / Black
Miles/Hours:
N/A
Engine:
Air-cooled, Twin Cam 96®, pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; 2-valves per cylinder
Displacement:
96 ci (1,584 cc)
Bore x Stroke:
3.75 x 4.38 in. (95.25 x 111.25 mm)
Compression Ratio:
9.2:1
Torque:
92 ft. lbs. (124.7 Nm) @ 3,000 rpm
Fuel System:
Electronic Sequential Port Fuel Injection (ESPFI)
Transmission:
6-Speed Cruise Driveâ„¢
Clutch:
9-plate, wet
Lubrication:
Pressurized, dry-sump
Final Drive:
Belt, 32/66 ratio
Frame:
Mild steel, tubular frame; rectangular section backbone; stamped, cast, and forged junctions; forged fender supports; MIG welded
Length:
97.5 in. (2,476.5 mm)
Width:
36 in. (914.4 mm)
Height:
49.3 in. (1,252.22 mm)
Wheelbase:
68.3 in. (1,734.82 mm)
Seat Height:
Laden: 27.5 in. (698.5 mm)
Unladen: 28.5 in. (723.9 mm)
Ground Clearance:
5.09 in. (129.29 mm)
Dry Weight:
650 lbs. (295 kg)
Fuel Capacity:
5 gal. (19.31 l)
Suspension:
Front Forks: 49 mm with polished aluminum fork triple clamp and dual-rate springs; 5 in. (127 mm) travel
Rear Shocks: Coil-over shocks; 4.1 in. (104.14 mm) travel
Brakes:
4-piston front and 2-piston torque-free rear calipers, patented, uniform expansion rotors (floating, front only)
Front: 11.8 x 0.2 in. (299.72 x 5.08 mm)
Rear: 11.5 x 0.23 in. (292.1 x 5.84 mm)
Tires:
Front: D401F (MH90-21 54H)
Rear: K591 (160/70B17 73V)
Rake:
34°
Trail:
5.1 in. (129.54 mm)
Insurance:
Request A Quote
Fatbob bagger
Jun 23, 2019 07:06 AM
rhuff
Motorcycles For Sale
Jun 18, 2019 12:27 PM
FXR_Hamster
Aug 18, 2012 11:31 PM
AZ Rider
Jul 8, 2007 03:35 AM
