Derby Cover install
Old Jul 8, 2007 | 05:36 PM
greg3131's Avatar
greg3131
Default Derby Cover install
waiting for the brown truck to arrive with skull derby cover and gasket. is this install easy?
could anything go wrong? thanks
Greg 07 streetbob
Old Jul 8, 2007 | 05:47 PM
Black Bart's Avatar
Black Bart
Default RE: Derby Cover install
It's an easy install Greg. Just be sure you have the required gasket to install in place of the old one. And while you've got the cover off you might as well do a clutch adjustment and maybe change out the fluid in the primary. See how much fun this is! Doing upgrades can motivate one to accomplish other things at the same time. Have fun!
Bart
Old Jul 8, 2007 | 05:53 PM
ClarkFXDC's Avatar
ClarkFXDC
Easy job, you'll need a T-27 torx. Tighten the screws in a star pattern
Torque spec is 84-108 inch lbs.If you don't have a torque wrench just snug them up, they don't have to be real tight.
Old Jul 8, 2007 | 05:58 PM
Dynamite17's Avatar
Dynamite17
I was surprised to see the new gasket (frisbee style) is different than the stock O-ring style. Hope you ordered the right new one.
I put my bike on a level suface and put the kick stand on a 2x4 and not a drop leaked out. My Sears 3/8 socket Torx bit broke at about 70 lb-in (using a torque wrench) so I just ended us snugging them up with a hand Torx wrench.
Need to order a set of tempered Snap-On Torx bits. Why the frick do they use those instead of Allen bolts?
B
Old Jul 8, 2007 | 06:59 PM
shoptroll's Avatar
shoptroll
So that you can buy a genuine Harley-Davidson set of Torx tips and some chrome replacement screws for a hunnert-dollers!
Old Jul 8, 2007 | 07:08 PM
GentlemanBiker's Avatar
GentlemanBiker
Put some 2x4s under your side stand or put it on a lift before doing this mod. Otherwise you'll likely end up with a puddle of oil. Otherwise, it's a pretty simple mod. Do read the installation directions, as there are some specific ones about which hole in the gasket goes where, etc.
Old Jul 8, 2007 | 07:14 PM
DGlide04's Avatar
DGlide04
A good quality #27 Torx bit is a must unless you want to strip them out. A little anti-seize compound on each one when you reinstall the screws will help the next time you have to take the derby off.
Old Jul 8, 2007 | 08:18 PM
gman's Avatar
gman
get rid of those phony torx bolts. get some chrome allen head ones from Ace Hardware. no more stipping, and they are a hell of a lot easier to get off next time.
Old Jul 8, 2007 | 09:28 PM
greg3131's Avatar
greg3131
thanx for the tips on the install.
Old Jul 8, 2007 | 10:14 PM
bikecop40's Avatar
bikecop40
I installed the same cover on mine Very Easy,,,,,, just make sure you don't keep the bike too level ( tip over risk ) 2x4 under the jiffy stand will do the trick, 15 to 20 min job
D/C............... I saved the old cover and old O Ring gasket
