Wide glide ape center width help!!
Old May 17, 2019 | 11:21 AM
WideGlidin05's Avatar
WideGlidin05
6th Gear
Default Wide glide ape center width help!!
I’m trying to buy a pair of 16 inch apes this week looking for 1 1/4 that will work with the stock clamp. My problem is I don’t know what center width to go with so that the bars don’t hang out past the forks. Way to many bar choices out there I don’t want to buy the wrong set up.
Old May 17, 2019 | 11:56 AM
nevil's Avatar
nevil
Maybe I'm missing something but why can't you measure for the width you want?
Old May 17, 2019 | 01:14 PM
SJK01's Avatar
SJK01
Maybe the reference information here can help you:
http://www.sideroadcycles.com/Americ...tock_Bars.html
SJK
Old May 17, 2019 | 01:18 PM
Architect's Avatar
Architect
Years ago Dennis Kirk catalog had Flanders bars for sale, with a full chart of dimensions including the bottom width you seek. Google both of them see what you find, I know what you are saying, those super wide bars hanging over the upper tree looks silly. Good luck.
Old May 17, 2019 | 01:27 PM
WideGlidin05
6th Gear
Well I ended up going with a 10” center width 17” rise and 11” pull back. Hoping I will like the fit. Only time will tell now. I’m hoping I am right by saying center width is from inside of the bar to inside of the other bar at the mounts? If this is the case it should put them at 10” + the 2 1/2 for the thickness of the bars? Am I doing this right? So the over all width at the clamps would be 12 1/2 to the out side?
Old May 17, 2019 | 03:42 PM
on3wego's Avatar
on3wego
Can you just look for images of them installed on your model? That way you'll know what to expect.
WideGlidin05
Apr 28, 2019 08:34 PM
jesse8931
Apr 17, 2015 05:47 PM
Yellotsacul
Oct 22, 2012 05:43 PM
Uncle_Timmy
Feb 27, 2008 10:43 PM
Halfbuck
Feb 14, 2006 11:01 PM
