Handlebar questions.
Old Apr 16, 2015 | 08:50 PM
jesse8931's Avatar
jesse8931
Default Handlebar questions.
Ok so I want to change out the drag bars on my 2001 1200c however I want the bar's or close to the ones on the 1200t
However my bike has the tall riser.
So what parts will I need and where would I order them from ?
Old Apr 17, 2015 | 11:13 AM
jesse8931's Avatar
jesse8931
bump.
Old Apr 17, 2015 | 05:47 PM
Mick's Avatar
Mick
Are you just looking for a different riding position?
The riser is approximately 6" tall ?
Generally a drag bar has no rise.
Here's some specs to pour over ...
http://www.sideroadcycles.com/Import...ckBarsOne.html
The stock bars should be about 27" wide , 5 1/2" pullback , 8" center.
Maybe what you want is a flat track style bar that's around 27" wide , 4 1/2" rise (tall) , 7 1/2" pullback , whatever center fits.
The center measurement refers to the straight part at the upper clamp area , if the center is wide enough , it will work , even if it's shorter than 8" like the stock drag bars.
The E5 would be something to check out here.
http://www.sideroadcycles.com/Import...t883_Type.html
Bars are hard to visualize , but know what you want to accomplish and measure twice , install once.
Mick
polbit
2018+ Softail Models
Aug 12, 2019 05:47 PM
Fairbanksdmt
Jul 31, 2014 12:44 PM
John Harper
Dec 23, 2011 12:42 PM
lawdawg81
Jan 21, 2011 10:07 AM
dawg
Feb 23, 2007 11:01 PM
