Speedometer not working
Old May 28, 2019 | 08:53 PM
nhcrtr's Avatar
nhcrtr
2nd Gear
Originally Posted by Huggerbugger
Perhaps he swapped out the ecm and the ecm thinks you're trying to alter the Odo.
The thundmax tuner is an entire ecm replacement.
Old May 28, 2019 | 08:54 PM
nhcrtr's Avatar
nhcrtr
2nd Gear
Originally Posted by Jay Guild
Also continuity test from the speed sensor to the ecm
I checked for the voltage going to the speed sensor and the ground for the speed sensor. I got 5v going to the speed sensor and the ground was good.
Old May 28, 2019 | 09:07 PM
Jay Guild's Avatar
Jay Guild
There is a third wire that sends the signal back to the ecm
Old May 28, 2019 | 11:53 PM
DTTJGlide's Avatar
DTTJGlide
I know that the mileage is contained in the BCM, so I'm thinking that all speedo functions are controlled there also, that's where I'd be checking since you have BCM fault codes.
Old May 29, 2019 | 09:41 AM
Jay Guild's Avatar
Jay Guild
When you replaced the speedometer did the new one load the same odometer reading as the old one?
nhcrtr
Electrical/Lighting/Alarm
May 22, 2019 12:47 PM
Renegade946
Apr 20, 2018 04:18 PM
harleyfiremedic
Jul 15, 2013 11:39 AM
Beercan321
Nov 9, 2009 02:14 PM
Jkid
May 3, 2007 05:02 PM
