96" to 110" Street Bob
Old Jul 18, 2019 | 11:39 AM
610Low's Avatar
610Low
Default 96" to 110" Street Bob
Hey y'all so figured I would start a thread for my new 110" build. Was thinking of selling my 2008 FXDB and picking up a 2017 FXDLS but this made more sense to my pockets since Ive already got the dual disk, FXDLS wheels, and I would end up deleted the ABS on a FXDLS. So Im on the road for the next 7 weeks and I dropped my FXDB off to my buddy at his indy to open up the engine. Below is a list of what I've got on the plate for him so far, just wondering what else y'all think I should throw at him to stack more work on him.
S&S 110" Sidewinder Kit
S&S 89cc Super Stock Heads
Feuling 574 Cam Chest kit with High-Flow fuel pump
Front & Rear oem motor mounts
Barnett Heavy Duty Clutch Spring
He'll also be trimming the spacer in my forks to give me a little room for adjustment on the Pre-Load adjusters. Some powder on a few parts, and a quick single color paint job. Hit me with some other ideas of what I should do to bring a little more to the bike.
Thanks in advance for all the input.
Old Jul 18, 2019 | 11:58 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Looks like that is going to be a nice bump in power.
Ask them to take the time to machine the cylinders to get zero deck and use 0.030” gaskets. Sometimes the pistons can be way in the hole.
Dave
Old Jul 18, 2019 | 02:34 PM
Dyna100's Avatar
Dyna100
If you still have the stock 46mm throttle body, you should upgrade to a 50-58mm with bigger injector. The SE 50mm comes complete with 4.9 injectors for less than $400.00
Old Jul 18, 2019 | 02:36 PM
Dyna100's Avatar
Dyna100
I'd also get a Predator mount for the front instead of the OEM. It made a huge handling difference on my DL.
Old Jul 18, 2019 | 02:57 PM
1bestfriend's Avatar
1bestfriend
Sounds like you’ve got a good plan.
Have you considered gear-driven cams?
Old Jul 18, 2019 | 03:31 PM
Suede Blue Man's Avatar
Suede Blue Man
Exactly.
Old Jul 18, 2019 | 03:47 PM
610Low's Avatar
610Low
Predator was on my list, but I was able to get an OEM set for a steal and after talking to tons of friends that know my riding style I figured I would get just what I need out of OEM for now.
The thought crossed my mind but I really wasn't to keen on the difference. My 574 camchest kit came from a friend of a friend for a good deal.
Exactly.
Like I said above, Predator was on the list but given my riding style currently I think I can survive with OEM for now after the recommendation of some friends.
Old Jul 18, 2019 | 03:48 PM
610Low's Avatar
610Low
I was up in the air if I would need a larger throttle body but after some reading I was of the understanding it wouldn't be needed. Ill have to look into it some more.
Old Jul 18, 2019 | 03:49 PM
610Low's Avatar
610Low
Decided to go ahead of pick up a set of Tokico GSXR 600 calipers and the Speed Merchant Radial Caliper mounts.
Old Jul 18, 2019 | 06:05 PM
Dyna100's Avatar
Dyna100
I guess your riding style doesn't include any canyon riding or speeds over 80 mph.... My choice would be the Predator over the new brake calipers.
You'll definitely be giving up HP & Torque by keeping the 46mm TB.
