Tail light/plate relocation
Old Aug 2, 2019 | 06:49 AM
201648rider's Avatar
201648rider
Stage III
Default Tail light/plate relocation
Just picked up an fxdls and I'm having a hard time finding a decent rear plate/light setup.
Setting the bike up for two-up with a sissy bar and quick release for additional bags if needed so I'd like to move the plate from lower left to rear center.
I would like to eliminate the stock hollow turnsignal/bolt hardware and just relocate everything back and center. Primarily to get things out of the way but I also plan on riding long distance and my last bike had a habit of breaking any hardware short of grade 8 bolts.
Does anyone have any recommendations for a slim LED setup that is decently visible? I went with the DK custom setup on my sportster (LED under fender) and was pretty happy with that but the integrated turn signals are a bit too close together.
Thanks in advance,
Old Aug 2, 2019 | 06:56 AM
Qdog002's Avatar
Qdog002
Great Bike Gear turn signal relo.
Old Aug 2, 2019 | 11:08 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Thanks in advance,
And this is why they don't pass the DOT spec.
Old Aug 5, 2019 | 06:52 AM
201648rider
Stage III
Thanks this is what I was struggling to find, buggers are pricy though!
I think I might have a go at making a custom one first, something that follows the curve of the fender a bit more, but I'll keep this one in mind when I inevitably fail.
Old Aug 5, 2019 | 07:28 AM
Qdog002's Avatar
Qdog002
Best option out there for what I wanted. Buy once, cry once. Well worth it.
Old Aug 6, 2019 | 12:06 AM
TOE_CUTTER's Avatar
TOE_CUTTER
You can find some pics of my set-up here:
https://www.hdforums.com/forum/dyna-...-ripper-5.html
It is a Cycle Vision Slick Signal 3 Function Licence Plate Frame. Use at your own rise.
Dave
Old Nov 5, 2019 | 06:40 AM
201648rider
Stage III
Ended up going with that cyclevisions unit. Very pleased with how it tidied things up.
Its much more visible that stock and eliminates my floppy sideplate the previous owner cobbled together (was rubbing on belt guard).
Being honest the install was a pain in the ***, particularly when using the top hand venture sissybar. I had to not only bore all the plate bracket mounts out but drill out the oddly slotted sissbar holes too.
Then sandwiching everthing in the proper order and dropping it on was very awkward. Still well worth it for what I was after.
Bonus - it stops the tire from flinging mud all over my fender.
Thanks for the recommendations!
Prog Geezer
Mar 10, 2014 07:45 PM
LeadSSled
Aug 25, 2013 05:57 PM
keno
Jun 17, 2013 03:46 PM
working_wood
Apr 13, 2013 07:09 AM
olgreydog7
Apr 3, 2008 01:28 AM
