Decel popping
Old Sep 12, 2019 | 09:15 AM
Jay Guild's Avatar
Jay Guild
Originally Posted by rikkitony
Just curious on how to find a leak with smoke when the motor is NOT running, to check an intake leak you would obviously have to have the motor running to listen for idle change, is that not correct?
I don't believe you can and the post you replied to didn't say you could.
Old Sep 12, 2019 | 01:56 PM
crusader1xxx's Avatar
crusader1xxx
Pretty sure this is what ...your second or 3rd post on this? You have already been told how to fix it...why are you asking again?
https://www.hdforums.com/forum/dyna-...l-popping.html
https://www.hdforums.com/forum/dyna-...treet-bob.html
https://www.hdforums.com/forum/dyna-...decel-pop.html
Old Sep 12, 2019 | 02:09 PM
Bluesrider.df's Avatar
Bluesrider.df
There's a simple way to check for exhaust leaks on a cold bike, I've done it myself. Mix some water & dish detergent and spray around the exhaust ports at the engine. Take a ShopVac hose and put it into the end of the exhaust pipe, and connect it to the vac so it is blowing air instead of sucking. Fire that momma up. You might need to use a rag to seal the vac hose so it's putting pressure in the exhaust. If there's a leak, you'll see bubbles right away at the engine. My bike has what looks like dual exhaust, but they aren't independent, so I had to cover the other exhaust pipe to do this test.
I replaced my exhaust gaskets to fix this. Definitely use copper gasket sealant. The FSM says this is optional, but in my case it was a requirement.
Old Sep 12, 2019 | 08:15 PM
crusader1xxx
https://www.youtube.com/watch?v=HK2zDBlcgOk
This only works if you have a leak when the engine is cold....sometimes they only start leaking when hot....as everything expands...but it is a good way to do it...
Old Sep 16, 2019 | 08:40 PM
Pylot7's Avatar
Pylot7
There are two reasons for decel popping.
One is overly rich and the other is overly lean.
You have Vance and Hines slip ons. You have a leaned out motor.
Tune it up and your decel popping with evaporate.
Old Sep 20, 2019 | 06:52 AM
rikkitony's Avatar
rikkitony
I apologize for the 2nd or 3rd post, I don't know what I was thinking, how can I live with myself, I guess I'll just have to go on day by day.
The reason for the other posts was that I was asked for more info and a new post is more likely to be seen, and I got good info on the third post, I didn't know my posts were gonna be investigated, I would rather be out riding more than I would be sitting at the computer investigating someones posts, but thanks for letting me know.
Old Sep 20, 2019 | 10:32 AM
Jay Guild's Avatar
Jay Guild
Out there throwing shade, huh?
aces&8s
EVO
43
Jun 28, 2021 04:52 PM
Prologix
General Topics/Tech Tips
Aug 18, 2016 08:40 PM
quietguy3099
Aug 20, 2012 10:49 AM
otter8
Mar 29, 2011 06:09 PM
paulydg
Jul 29, 2008 01:04 AM
