Rear chain scraping against inner primary
Old Oct 20, 2019 | 03:11 PM
81Pinkie's Avatar
81Pinkie
1st Gear
Default Rear chain scraping against inner primary
I bought a 1981 Dyna Superglide Fatbob FXEF as a project. It came completely disassembled (empty frame) and in pieces. I have the build almost completed but after installing the rear tire and giving it a spin, as soon as the chain master link engages the transmission output shaft, the chain itself grinds against the back of the inner primary case. There are literally aluminum shavings on the floor. New chain installed with the Motion Pro kit, and new inner primary. When I installed the inner primary, i left the transmission loose on the frame so it could be drawn into the inner primary housing so it wouldn't crack. The chain is straight between rear tire and transmission when adjusted to length so I'm thinking that the sprocket on the xmsn output shaft is sitting too close to the inner primary housing. There is a gap created between the starter drive gear housing and the primary casing itself. I think the chain should reside in the centre of that gap. When I look down the chain from the rear tire, the chain sits extremely close to the inner primary. When the transmission was on the bench, I made sure everything was tight, and operating properly. The trans mounted like it should on the frame, all bolt holes lined up perfectly. Was there a difference in transmissions for different models? Can anyone help?
Old Oct 20, 2019 | 08:59 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Standard drive chain or o ring chain?
Old Oct 20, 2019 | 09:19 PM
81Pinkie's Avatar
81Pinkie
1st Gear
Hey Texas,,, Yeah it's an 0-ring chain. And it's only the master link that's scraping. I appreciate any advice you can offer...
Old Oct 21, 2019 | 02:01 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Just a note, your bike is not a Dyna. It belongs to the FX family before the FXR. Your bike is usually talked about in the Shovelhead section.
Now that's out of the way, lol, it sounds like you need a spacer on the inside of the sprocket. J&P Cycle part number 6200001 is 0.085". Some year sprockets came with that, but seeing you assembled a basket, who knows. Show us a pic of your ride!
Dave
Old Oct 21, 2019 | 07:45 AM
TexasScooterTrash
Good news for o ring chain - stays lubed thanks to o rings. Bad news is o ring chains are wider than standard chains. I would venture to say put a regular chain on it and the problem will be gone.
Old Oct 21, 2019 | 07:51 AM
John CC's Avatar
John CC
Maybe the answer is a riveted master link.
Old Oct 21, 2019 | 07:57 AM
Vec's Avatar
Vec
did you use a clip style master link?
you can flip the clip to the inside and see if it clears that way just be sure to put the clip with the open end towards the rear
Old Oct 21, 2019 | 08:22 AM
John CC's Avatar
John CC
Well, half the time, anyhow!
Closed end points in the direction the chain moves. On top the open end points aft, but on the bottom it points forward.
Old Oct 21, 2019 | 08:28 AM
Vec's Avatar
Vec
lol.... yes what he said
Old Oct 21, 2019 | 01:27 PM
81Pinkie's Avatar
81Pinkie
1st Gear
Maaaaan, i tried for about 2 hours yesterday to remove that master link without destroying it, just to reverse the darn thing. When i couldn't remove it, that's when i looked down the length of the chain and noticed that it sits about 1" (approx) from the transmission and about 1/8" from the back of the inner primary and said to myself... nah, something's not right here. But I didn't, in the slightest, think the o-ring chain was wider than the OEM one, although it makes total sense. I'll get out my vernier today and take some measurements, but i'm sure that's the issue. VERY much appreciate the feedback... thank you all.
