brake light problem
Old Dec 13, 2019 | 04:25 PM
christian parks's Avatar
christian parks
Stage IV
Default brake light problem
i have a 2009 fxdf . when i turn the key to accessories and i depress either the front or rear brake pedal the headlight and the rear brake light come on.also fuel pump primes up, when i turn the key to on position i have headlight high and low operation, and turn signals are fine. but no rear brakelight i have replaced the rear brake light switch the rear brake lamp circut board, still having same problem , have checked the grounds under battery box ground 1 and 2 i have good ground. can anyone help me figure out what is going on please?
Old Dec 13, 2019 | 06:08 PM
John CC's Avatar
John CC
Are you saying the fuel pump runs when you apply the brake?
When several seemingly unrelated circuits interact, the grounds are the first place to look, Where is your fuel pump ground? Headlight? Brake light?
Do your self a favor and edit your other post into an "oops, sorry" before someone jumps all over you...
Old Dec 13, 2019 | 07:32 PM
christian parks
Stage IV
i thought that all the grounds went to the grounding block under the battery compartment. yes im saying the fuel pump primes up when brake is engaged front or rear when in accessory. im not sure of any other grounds . i havent been able to find any,
Old Dec 13, 2019 | 08:00 PM
Bob_fxdb's Avatar
Bob_fxdb
Just got the bike? If yes, looks like the person before you messed up with the wiring... smells fishy. If not, no clue, just need to go trough the wiring anyways I guess. Sorry 😐
Old Dec 13, 2019 | 08:02 PM
Bob_fxdb's Avatar
Bob_fxdb
And the headlight 😅
Old Dec 13, 2019 | 08:09 PM
christian parks
Stage IV
no have had the bike 4 years never any problems except a blinker fuse.
Old Dec 13, 2019 | 08:59 PM
cggorman's Avatar
cggorman
The entire frame is ground. Just like most cars. Pretty much any small diameter black wire is a ground, whether or not it terminates near the battery.
Some ground wires have colored and/or striped insulation. Refer to the service manual wiring schematics.
_allergic2u
Sep 7, 2016 07:22 PM
longhaul-2007
Sep 29, 2013 12:16 PM
Kmarc86
Aug 31, 2013 09:57 AM
gilmour68
Jul 13, 2009 06:48 PM
mja52403
Mar 4, 2009 05:26 PM
